Car: 1993 Nissan Skyline GTS-T
History: This vehicle was owned and built by a mechanic in Sydney. I purchased the vehicle in Sydney, November 2006. I have receipts for over $45K worth of mods. Vehicle was tuned well, always warmed up properly before driving and always serviced every 5000kms. This car has been so reliable which is rare with fast imports, genuine reason for sale, saving for a house.
Condition: Body and Mechanical is great, paint has stone chips on front bar.
Contact: PM or 0433 581 362
Price: 14,900
Power: 360rwhp @ 18psi
Mods:
- Forged pistons
- Seal pro rings
- Arp Head stud kit. 1.8mm Metal head gasket.
- Ported and polished head. Worked internals
- Isky 90 PSI Valve springs
- Reground cam shafts
- Gates racing belt
- Oversized adjustable cam gears
- XTR 30/40 bb turbo with XTR turbo nappy
- Sard 660cc injectors
- Sard fuel pressure regulator
- Xtr Motorsport 750HP fuel pump
- Ceramic coated exhaust manifold
- Port matched 38mm Tial Wastegate
- GReddy Blow off Valve
- GReddy Oil catch tank
- Iridium spark plugs
- Z32 Air flow meter
- Spitfire ignition coils
- HKS Pod air filter
- HKS Super dragger exhaust
- High flow cat. Heat wrapped dump pipe
- Screamer pipe
- Electronic Boost 2 controller (EBoost2)
- Apexi Power FC and hand controller
- R33 GTR Intercooler with custom piping
- Lightened fly wheel and ceramic heavy duty clutch
- Kaaz 2 way locked diff
- Whiteline sway bars
- Whiteline suspension kit, King Springs
new pics:
Edited by 11DOU
https://www.sau.com.au/forums/topic/175847-big-hp-1993-skyline-r33/
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 years later...
This is a old bump but surprised the hell out of me when I saw it. This is my Racecar atm! My brother bought it off ya and now its no longer a street car but a track weapon! It has been tuned since to 381hp and a huge list of suspension and brake mods have been done. Also a custom sidepipe has been added and a aluminium radiator. It has not had the engine opened since and is still strong as! heres some pics
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
