Hey All.. Got a problem I'm hoping to get some help on..
My Flat mate drive an R33 4 Door GTS-t and is having a problem with her Hi-Cas.. Basically after about 11k's or so.. the HICAS light comes on the dash display panel.. It's been to the mechanic several times, been 'fixed' several times, but to no avail...
Last night I was looking at an engine manual I downloaded from www.rb20det.com (before the comments come, yes I know it's a different engine) and it was saying somethign about HICAS not working properly if the power steering belt is not tight enough...
My question is.. Has anyone here had any problems with their HICAS? If so.. what was the soloution? Maybe something Will fix it..
The relays and sensors have all been checked, and the hicas computer replaced.. (so the mechanic said) ...so I would imagine that anything different to what has already been tried may work?
Any Feedback would be great..
Cheers
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/
Speaking of HICAS!!!
Mine came on and put me into a gutter today - tore apart my passenger side suspension assembly.... ugly ugly stuff...
HOTR33 - do a search for HICAS problems or something like that - there's tonnes of links...
Ive had so many problems with mine - flicks the tail out when the light comes on etc....
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/#findComment-366163
hey..yeah i have the same problem!! its based on kms travelled..cos every single time it comes on at the same place!!!
is the steering wheel stock? cos it happened to me after i changed my steering wheel...and boss kit....it is a hicas one..but apparently it is heaps hard to fit it properly so as not to get the light to come on ...and yeah HMS told me that they cud do it so the light doesnt come on..but that was bullshit!!
yeah newayz...i havent really found much of a problem with having this light turn on...neone care to correct me??
cos I am not sure wot it means either..!!
neone had this problem and fixed it??
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/#findComment-366172
friend had the same problem and it was because of fitting a aftermarket steering wheel on. the boss kit was standard, apparently u need a special boss kit designed for the hicas system. so far i only know of one place that has the proper one....Unique autosports but they are a very expensive bunch of people charging $150 or $200 (not sure) just for the boss kit !!!
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/#findComment-366205
If you fit an aftermarket steering wheel, you must fit a HICAS compatible BOSS and make sure it is aligned (fitted) correctly - otherwise the HICAS light will come on.
The HICAS system (AFAIK) isn't linked directly to the front steering system. Sensors on the steering column (plus a speed sensor) send info to the HICAS computer (located in the trunk), from there steering ajustment on the rear wheels is made by the HICAS system at the rear. Check to make sure all the connections are secure, there's no corrosion or anything like that...
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/#findComment-366238
Happens to me only on the motorway and always in the exact same position.
I can tell when it is going to come on right down to the centimetre.
Have won bets as to when it is going to come on. Spins a lot of people out.
But, i'm through winning bets, i'd like to know how to fix it.
And yes, it does have an aftermarket Steering wheel but it was on the car when it came from Japan so i don't know what Boss kit is being used.
Any help would be appreciated.
https://www.sau.com.au/forums/topic/17596-hi-cas-problem/#findComment-366419
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
