hey guys ive just replaced the rb20det in my ceffy with another 1 i got it all hooked up and started it and didnt seem to run right it sounded like the timing was out and wasnt firing properly and also pissing out black smoke so somehow to much fuel. i though it might of been an electrical fault since then i have had it at the auto electrician and he cant find any problems in the ecu or harness. the coil packs and sparkplugs are fine to. its possibly the crank angle sensor but thats all i can think of anyway
would any of u guys have an idea of wat i mean or would be able to help solve my problem?
cheers wes :D
https://www.sau.com.au/forums/topic/176059-problems-with-my-rb20det/
Clean all the sensors with contact is the first thing id do and also make sure all the wiring to the sensors is done properly. get timing checked (cas should be dead centre), also find out if your acutally running rich or lean as even tho it spits black smoke it might be leaning out everywhere else.
Edited by Mrlag
well all the electrical is fine so im told. but yea im gonna get the timing done tommorow along with the cas. but with the black smoke it wasnt there before wen running my old rb20 and i have tryed a new afm and it made no diffirence but somehow it seems to run better with the afm unplugged :D so yea not quiet sure
32 motor or ceffy one?
you swap the things over you needed to?
um i had originally the r32 rb20 in it and swapped with another rb20 from an r32 aswell so it should run just the same as the last one shouldnt it?
all being well that is but yea it was just a basic swap
hey guys just letting u no i changed the injectors and a new fuel rail and diffirent coil packs now its doesnt seem to have spark :) maybe i havent put a plug back in properly but yea i cant see a plug that hasnt been plugged in.
so im getting fuel ok now but no spark would any1 have any ideas?
hey guys just letting u no i changed the injectors and a new fuel rail and diffirent coil packs now its doesnt seem to have spark :thumbsup: maybe i havent put a plug back in properly but yea i cant see a plug that hasnt been plugged in.
Swap the igniter over? make sure the plug is ok on the igniter?
Hey mate yea ive had the ignitor swapped over to see wat was causing the problem the ignitor was good but that was about a week ago and i havent started it since so yea im thinkin possibly "cas" becuase it wont start now
cheers mate
check ur afm as mine was farked and pissed out black smoke also! cleaned the afm and all fixed!!!
hey man wen it was at the auto electrician they swapped the afm with a good one but still no good. the car actually ran better with out the afm plugged in :P
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
