My question is more on the way its fitted.. If it needs a pin throgh it, to be sure it wont spin on the crank.
Now its mounted this way: crank was cold shrunk, collar heated to 100 degress, both parts degreesed, special glue, VERY strong and will hold up to 150 degrees, still needed 2 tons to be pressed on. (No I did not press 2 tons down on entire crank, a metal bar was fitted just down under the first counter weight.)
Question is, do you think it will stay on and not spin round the crank. I dont know how much force there is trying to twist it around the crank.... How hard the oil pump is to drive..?
https://www.sau.com.au/forums/topic/176327-is-this-okay/
Rule of thumb from an old engineer when they used to press on drive sprockets. A 2 thou tolerence fit on a 1 inch pipe 1 inch wide will drive 40hp.
Thats an interesting rule of thumb when you think about it, as HP doesnt have anything to do with it does it!
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226313
It's to do with torque and how much pressure is being created outwards on the outer surface with the interference fit.
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226340
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
