Sorry don't mean to spam ur thread, jst want to set the record straight, as I mentioned before, GTT coupe and sedan suspension is exactly the same (front strut has an eye and rears have the fork)
What you have should fit an NA R34 sedan or coupe or a GTV as they are called. They have an eye on the rear strut instead of a fork. I have attached pics of my Teins to suit GTT sedan or coupe. Hope this clears things up and GL with ur sale.
cool thanks,
wasnt too sure which model it would fit.
so anyone want these beauties?? :)
would those pads fit 33 gtst?...i know the brakes are different but not sure how different. maybe same rear pads?...wouldnt mind getting front/rear pair if fitted and u dont mind seperating. cheers
If u can check the spring rates I would be interested in purchasing the springs off you, that is if ur willing to seperate.
i would prefer to sell them complete
sorry mate
Edited by Tommmo
not sure what the difference between the two is,
but once again i would prefer to sell them together
Hmmm interested in those coil overs, let me scrape together some money and then I will contact you - if you have not sold them by then!
In Adelaide too
In Adelaide too
pm sent
hey mate, how certain are u that these will fit a r34 N/A. have u put them in a 34? just wondering cause im looking at getting some.
cheers luke
price is negotiable
Worth a shot..
Meet you a bit over half way on the coilovers.. :pirate: (plus postage)
And will drop the money into your account today..
Cheers Wayne
cheers luke
i'm 100% certain these will fit into an R34 N/A
my friend bought r33 coilovers for his NA R34 thats how i know they fit.
if your still not certain, then just have a look at the photos and compare them to the bottom of your struts, as that is the only difference between them.
cheers
Worth a shot..
Meet you a bit over half way on the coilovers.. :rolleyes: (plus postage)
Cheers Wayne
not quite that negotiable, but was worth a shot :thumbsup:
cheers
just wondering. if i put these in my car, would everything line up. like would the heights been the same each end of the car if i have them on the lowest setting?
cheers luke
cheers luke
i wouldnt keep them on the lowest setting as you would lose your front bar :(
all the heights are even at the moment, so the car will sit quite even
In Adelaide too
have been sold!
enjoy buddy, hope you didnt have too much trouble putting them in :thumbsup:
Free Bump-I got a set if there the flex model there tuff as i got EDFC controller aswell cant go wrong with kantong...easy as 2 adjust and not bumpy @ all :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
