Make: Ford
Model: EL falcon GLI
Year: 1997
Colour: White
Engine: 4Lt 6 cylinder
Transmission: 5 speed manual
Body Type: Sedan
Odometer: 140,000 km
State: South Australia
Price: $5700.00 ONO
oil and filter changed every 5,000 km
Mods:
- 5 Speed manual converted from auto, with xr6 manual ecu
- xtreme heavy duty clutch kit and new thrust bearing
- momo black gear knob from AU falcon.
- mild Crow cam 2222519, with roll master vernier cam gear.
- new spark leads at 130,000km
- head gasket change at 130,000km, head was checked and faced at the time
- extractors and 2.5 inch cat back exhaust
- K&N airfilter
- replaced water pump at 135,000km
- new front brake rotors and pads (bendix advance), wheel bearings at 120,000km
- BA XR8 17x8 inch mags(copies) with 235/45.
- new battery at 120,000km extra heavy duty battery
- pioneer mp3 deck, sony 10inch sub and amp to suit
- tinted windows at instant windscreen(premium tint)
- EF XR6 LSD, recently rebuild with new spring pack, shims and machined cones.
- whiteline 30mm front sway bar and 24mm rear swaybar with all polyurethane bushes
- FRONT- superlow kingsprings and GT monroe lowered shocks and camber castor kit(shim type)
- REAR - low kingsprings and GT monroe lowered shocks.
i can be reached on 0423090436 after 6 pm
JIM
https://www.sau.com.au/forums/topic/176630-ford-falcon-gli-1997-manual/
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
