AS TOPIC STATES I AM SELLING MY OS CLUTCH
ITS A TRIPLE PLATE WHICH HAS DONE NO MORE THEN 1000KS DURING MY ENGINE RUN IN
IT COSTS BOUT $3400 BRAND NEW BUT ILL TAKE OFFERS CLOSE TO THE $2000 MARK
LOCATED IN STDNEY BUT WILL SHIP AT BUYERS EXPENSE
PM OR CALL ME ON 0404 866 327
RING ME UP AND TALK A DEAL
Edited by pitperformance
https://www.sau.com.au/forums/topic/176660-os-giken-triple-plate-clutch/
is there any warranty with it?
no warranty mate im not installing it for you and its second hand. only done 1000ks. i can personally "gauarantee" you though there will be no slipping at all.
ANYWAYS PEOPLE MAKE ME AN OFFER. GIVE ME A CALL 0404 866 327
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
