interested in driver side headlight,
can i have pics?
will send ya pics shortly pm me ya email and i will send them.
There series 2 lights with some small scratches
thanks slighten
Edited by slighten
  • Replies 69
Posted Images
gday dude.. pm'd you on the R31 forum but got no reply re: rear brakes..
im after the rear calipers, discs and drum shoes and whatever theyre mounted to..
you quoted me $250 delivered on the calipers and discs.. but i need the handbrake stuff aswell.. just the drum shoes and mounting stuff that is..
i asked you for bank details and sent you an sms also but didnt get a response. i have money, want the bits, let me know your price and freight to 7018 and we can go from there..
cheers, Kent
Hi mate, do you still have the driver side door ? I need the power window console cover (the panel that forms the door handle, as shown below)
I also need the steering wheel if you still have it + the rear spoiler LED light.
Let me know if you have any of these.
Thanks
Edited by Kryptonas
can i get pic of the bonnet??? is it in good condition paint wise? no chips or dents?
also is this series 1 or 2? is there any bonnet difference between series 1 and 2? i have a series 2 and need a bonnet for that
Kryptonas : pm sent
ashneel : S1 , not that i know off
R31Nismoid : sure do check the engine stripping thread in my sig
soslo_31 : shud have, will get bak to you asap, need 2 double check
skyline17 : sorry been busy, will get back to you about that lid as soon as i can
R31GXE3.0 : hey bud, sorry bout the late response. might be selling that in a pack soon, if not i'll send the caliper's and rotors right over,drums and lines mite be taken by local if not will post out as well
come get the rest pplz :)
Edited by slighten
no matter anymore, i assumed from the lack of response that you'd forgotten about this thread or something.. no matter, i've bought some elsewhere in the meantime.. cheers though
looking for the relay switch that runs the electric window.its in the door and its a little black box,near the door handle when you take the trim off,need one because mine one is stuffed!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
