Howdy Lads,
Got these parts up for sale due to selling my car.
Power FC
I got myself here a Power FC for a R33 series one engine without hand controller, i searched for months for one of these and imported it from Japan.
Price : $950 (can post anywhere needed)
Garret T04 Hi-Flowed And Rebuilt New Condition (never been used since rebuild)
0.63 rear housing
0.58 front housing
Rated 600hp
Two internal wastegates / hi / low spring
Optimum boost range 19-22psi
Full boost should be 3000-3400rpm on RB25
** Will put up pictures of turbo tonight **
Price : $800 (can post anywhere needed)
- Luke
https://www.sau.com.au/forums/topic/177017-power-fc-r33-gtst-garret-t04-600hp/
Hello,
Im located on the Gold Coast in QLD but can do postage at buyers expense.
Im unsure how it would compare all i know is for the size of this turbo its will be on boost fairly quick due to it being high flowed and it offers great HP potential. And ofcourse its Brand new condtion. Not a single km on it. Would be very easy to pull big HP if you have the correct gear with this turbo.
Bolt straights up to RB20 or RB25.
- Luke
Edited by RB20DET_Silvia
do you have any photos and receipts for the turbo?
what would be the expected rwkw figure you could get with this turbo on the right setup (r33 with power fc and all supporting mods)? what other mods will have to be done for it to fit? will it go straight on the manifold and oil/water lines etc?
btw im interested in both items
I would like to say its a t04e i believe it is.....but im unsure.
With this turbo and Power FC along with injectors or hi-flowed standard injectors, fuel pump, fuel reg and a tune you could easily pull over 400 to 450hp (300-340rwkw) at wheels, a aftermarket headgasket would also be a good mod to do if you wanted to run high hp all the time. If you wanted to go over 500hp you would need to do more engine work to run that HP everyday on your engine.
The turbo will straight bolt on to all your standard lines and manifold etc....
I found a picture of the turbo on my computer.
- Luke
wanna swap the power fc for some wheels ??? swap ya this weekend :) - everybody needs a spare set of wheels
http://www.skylinesaustralia.com/forums/in...p;#entry3233590
howdy, im interested in the turbo... u stated it had not seen any use since being rebuilt/high flowed and was done recently, I'm asking the same question someone else just did, do you have the reciept for this? cheers Damo
Hello im on the gold coast,
And i pm'd u all....and sorry wheels i do not need PFC is for sale for cash!
- Luke
You'll regret this...!!
haha nah, free bump for someone selling an rb25 pfc for a fair price!
regards to ur turbo.. is it suited to a t3 or t4 flange ?? also is it internal or external wastegate??
cheers chris
bro if u scroll up it says that the turbo fits an rb25 manifold( which is t3) and in the 1st post it says its internaly gated, plus if you look at the pic, u can clearly see the wastgate actuator, which suggests its.................internally gated lol
yea sorry guys alot of posts here.. prob didnt read through an yeh didnt click on the rb25.. my bad.. thanks anyway
i hav an external gate anywayz and if i get the turbs can just weld up the internal one
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
