Howdy Lads,
Got these parts up for sale due to selling my car.
Power FC
I got myself here a Power FC for a R33 series one engine without hand controller, i searched for months for one of these and imported it from Japan.
Price : $950 (can post anywhere needed)
Garret T04 Hi-Flowed And Rebuilt New Condition (never been used since rebuild)
0.63 rear housing
0.58 front housing
Rated 600hp
Two internal wastegates / hi / low spring
Optimum boost range 19-22psi
Full boost should be 3000-3400rpm on RB25
** Will put up pictures of turbo tonight **
Price : $800 (can post anywhere needed)
- Luke
https://www.sau.com.au/forums/topic/177017-power-fc-r33-gtst-garret-t04-600hp/
Hello,
Im located on the Gold Coast in QLD but can do postage at buyers expense.
Im unsure how it would compare all i know is for the size of this turbo its will be on boost fairly quick due to it being high flowed and it offers great HP potential. And ofcourse its Brand new condtion. Not a single km on it. Would be very easy to pull big HP if you have the correct gear with this turbo.
Bolt straights up to RB20 or RB25.
- Luke
Edited by RB20DET_Silvia
do you have any photos and receipts for the turbo?
what would be the expected rwkw figure you could get with this turbo on the right setup (r33 with power fc and all supporting mods)? what other mods will have to be done for it to fit? will it go straight on the manifold and oil/water lines etc?
btw im interested in both items
I would like to say its a t04e i believe it is.....but im unsure.
With this turbo and Power FC along with injectors or hi-flowed standard injectors, fuel pump, fuel reg and a tune you could easily pull over 400 to 450hp (300-340rwkw) at wheels, a aftermarket headgasket would also be a good mod to do if you wanted to run high hp all the time. If you wanted to go over 500hp you would need to do more engine work to run that HP everyday on your engine.
The turbo will straight bolt on to all your standard lines and manifold etc....
I found a picture of the turbo on my computer.
- Luke
wanna swap the power fc for some wheels ??? swap ya this weekend :) - everybody needs a spare set of wheels
http://www.skylinesaustralia.com/forums/in...p;#entry3233590
howdy, im interested in the turbo... u stated it had not seen any use since being rebuilt/high flowed and was done recently, I'm asking the same question someone else just did, do you have the reciept for this? cheers Damo
Hello im on the gold coast,
And i pm'd u all....and sorry wheels i do not need PFC is for sale for cash!
- Luke
You'll regret this...!!
haha nah, free bump for someone selling an rb25 pfc for a fair price!
regards to ur turbo.. is it suited to a t3 or t4 flange ?? also is it internal or external wastegate??
cheers chris
bro if u scroll up it says that the turbo fits an rb25 manifold( which is t3) and in the 1st post it says its internaly gated, plus if you look at the pic, u can clearly see the wastgate actuator, which suggests its.................internally gated lol
yea sorry guys alot of posts here.. prob didnt read through an yeh didnt click on the rb25.. my bad.. thanks anyway
i hav an external gate anywayz and if i get the turbs can just weld up the internal one
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
