Brand New D2r Hid Globes, Direct Drop-in For R34's With Factory Hid, 2 X 6000k And 1 X 8000k
As the title says, these are brand new drop-in replacements for those highly expensive HID D2R factory globes.
Can be replaced in minutes, I've got
2 x 6000K sets (very white)
1 x 8000K set (slight blue hue) SOLD
$75 for a set (2 globes) delivered express throughout Australia.
Hey Dan, how do these compare with the stock HID's? (The 6000k ones)
And would it match the color of your LED's?
Edited by Fujiwara
They're very close in colour to the LEDs actually, I always think (being fussy) the stock HID are slightly less blue than the LEDs. This could be due to age of my factory ones though. Also the new bulbs have a slight colour shif after 500 hours and get a bit white-bluer.
Got decent white (but not noticeably illegal) replacements for halogens? Bastards at compliance never returned my Xenons...
Sorry no halogens, only HID
whats the kelvin rating on the stock HID's?
And can the wiring/loom handle 8000k
8000K refers to the colour temperature, they don't use any more current load than the stock globes, these are 35W just the same.
I've heard figures of 4200-4700K for stock...I'm tending toward the 4700K
i got 2 sets of dan awsome xennon bulbs .. huge diff over stock 4200k xennons.. thanks a bunch bud for them :banana: well worth the money
P.S my fatory booklet states mine was a 4200K maybe the earlier ones were different??.. 8000K is worth it :yes:
Edited by 53XYN
does the 8000k still light up as much or more as the standard ones?
I haven't done the 6000K side by side with the 8000K, but it was brighter than the stock ones, just with a bluer tinge to it. My stock ones are older though and probably getting toward the end of their useful life.
Dan just letting you know i found my steaga S2 lights they use D2R as well your 8000K ones fit in Steaga perfectly exact same setup as 34
S2 Steaga are Xennon Series one stock H4 or H1..
Edited by 53XYN
I used a stock loom for 9000k with no problem at all.. :cool:
i tried to take out my globes today and found out that there is a star shaped allen like key thing there.
WHERE THE HELL DO I GET ONE AND WHAT SIZE IS IT!!!???
Can any of you guys help me? As i'm getting a set off dan.
Cheers
Cheers
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :D
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :P
i don't want to be doing that.
knowing me, i'd break alot of things
You turn the cover with one hand, keeping pressure on it, flip the plastic tab with your finger slightly and it'll jump over the screw. When you do it up, just don't force it past when you screw the cover back.
Hey ,mate.
Just sent the payment through.
Please send me a set of 6000k globes.
Also which way do i turn the covers and how much do i turn them to take it off?
Is there no place that sell the star shaped allen keys? :laugh:
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
