you need to give us more information.. the only thing we can deduct from what you have told us so far is that your not making what you should be.
even with the stock computer you should make more then that at 13psi. post up the graph, gives us a complete run down of mods (afm, injectors, pump etc), what did your tuner say, anything unusual happening etc
I'm in mildura no1 here that knows what there on about.
it is an sr20det running
-full exhaust including masa motorsport extractor manafold
-pod filter
-600x300x90 front mount
-bosch 044 fuel pump
-HKS GT2530 turbo
-13psi
as far as the computer, injectors and fuel reg, air flow meter are all standard.
The only thing the tuner said was the fuel was slightly on the lean side lower in the rev range before it comes on boost and richens up to the top but 12.5-1 which is on the lean side anyway.
I have attatched the dyno graph of my last 2 runs the blue is with a HKS gt2540 and the red is the same mods but with a HKS gt2530.
Hope there is enough info there
-pod filter
-HKS GT2530 turbo
-13psi
2530 has a much nicer power curve scribble :D
cant help with ur problem though :S sorry
stock ECU is the problem.
it's not tunable (well it can be re-chipped) but you said yours is stock.
so it's gonna run like a bucket with all that extra air flow.
stock Fuel pump too?
you need.
Power FC
Injectors
Fuel pump
18psi.
that should be plenty for over 200rwkw
and obviously a good tuner.
you need.
Power FC
Injectors
Fuel pump
18psi.
people pull more then 160rwkw on the stock ECU all the time, i dont think thats the issue
13psi on a 2530 isnt really much airflow, you can get that on the stock turbo.. the t25g can usually pull 175-180 with the support mods on 1 bar/~14psi
he also mentioned he had a bosch pump
if its lean, then 'richens' up to 12.5 in the top end you have a fuelling issue (check fuel pressure), your graph is very choppy. be aware that your injectors are going to max out very soon though, they definately need an upgrade for the full potential of the 2530 and also you need to swap your afm for at least an rb25 one.
13psi on a 2530 isnt really stretching her legs out..
so the scribbly graph could be to do with fuel reg ???
so as far as next upgrade for bout the 200rwkw mark which id be more than happy with would 550cc for injectors with a decent fuel reg, and air flow meter upgrade, is there a direct bolt on larger replacement ???? or what ever i do i need at least an ecu tune ????
the problem you have at the moment is the stock ECU!!!!!!!!!!
what it is doing is seeing the extra pessure and retarding the timing hence the reason you have power all over the place, you might have an issue with your fuel reg but you would usually having other problems with it like hesitation stalling etc when not on boost (however i could be wrong), i say get yourself a decent ecu some new injectors and a new afm as it will start to run out of res at around the 200rwkw mark. get it tuned and you should be making some good power
do you even have any experience with sr20det's ??
the ecu doesnt see boost pressure fyi, it sees airflow from the afm. the stock t25g can run 1bar of airflow no problems on the stock ecu so i dont see how you deduce the ecu as the problem.
it would help your case alot if you could provide afr's and boost pressure layed ontop of that dyno sheet. but basically with the way the stock ecu behaves you should be getting around 10:1 afr's in the top end, not ~12.5. this would indicate lack of fuel pressure or lack of flow from the injectors. your already pushing it on the injectors in terms of flow, and so even a slight lack of pressure could push them to 100% where they will max out. its rare to find a faulty FPR, but first thing i would be doing is having your fuel pressure checked through the rpm range. did the tuner say what duty cycle the injectors were hitting ?
fwiw i ran a gt2530 turbo on my previous sr20det and pulled ~220rwkw on about 17psi with all supporting mods including step 1 cams. i also had similiar drama with fuel flow, it ended up being a 'faulty' walbro pump even though it was an original.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
