Hi all,
Time to sell some stuff...
Std R33 standard turbo - $300 (Sold)
Std EX manifold - $50
Std Throttle body - $40 (Sold)
A/M Dump pipe (single pipe) - $60
Std intercooler - $50
new T70 Turbo kit - High mount manifold - Turbo - 35mm Wastegate ---- $700
All prices are ONO
Buyer pays postage - located in Gladstone Qld, pick up welcome if u happen to live close by... unlikely
other exhaust and intake parts available just can't think of them at the moment...
Edited by axe s
https://www.sau.com.au/forums/topic/177190-r33-gts-t-parts/
will you post the std intercooler to mackay/walkerston?
Post anywhere at your expence....
And no it's just the dump pipe not a front pipe (as i'll be able to use mine on new system)
https://www.sau.com.au/forums/topic/177190-r33-gts-t-parts/#findComment-3238128
do u have a stainless induction pipe to the front of the turbo?
front strut brace?
https://www.sau.com.au/forums/topic/177190-r33-gts-t-parts/#findComment-3238261
My internet is totally screwed so i would PM you but i cant haha.
Im very interested to get more details, if you could give me a call on 0419987212. ill probably take it off your hands.
Cheers mate.
yeh, i'll give you a ring as soon as i can... middle of moving,
https://www.sau.com.au/forums/topic/177190-r33-gts-t-parts/#findComment-3254385
  • 5 weeks later...
  • 5 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
