there defiantly forgies. The piston you have are sold by precision performance. they retail for $1500. they are some chinese brand but dont be to worried there no to bad really. these are mine that we put in rb30's for a cheaper optioned rebuild. Just put it all back together and drive it, as lond as there not damaged it will be sweet. cheers
mate.. you are a legend! :)
I owe you a beer!
:D
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3244710
  • Replies 64
Those pistons are Hypatec liquid forged. They are a semi forged piston and are hypereutectic. They are sold by Precision International, they are not a bad piston though I haven't used them in any turbo engine.
More info here: http://www.precisionintl.com/HTML/product/...hypatec_lf.html
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3246111
my advice is now that you know what brand the pistons are, contact the piston manufacturer and ask them wat PTB clearance they reccomend. it may in fact be 0.1mm (unlikely, but possible).
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3247161
**UPDATE**
I WAS looking for a piston to bore clearance of .035 - .05mm (as per Manufacturers requirements)
Called up some blokes down at Silverwater and .1mm seems too big..
So..
plan of attack..
Piston size of 85.95mm WILL fit a stock RB25DET bore and have a gap of .05mm (recommended gap) - Anyone interesed in a cheap set of forgies that will fit stock Rb25DET bore?
BUT
Because the mechanics at deadshit's mechanics R US bored the block out by .05mm (and hence increased the clearance to .1mm and therefore too big) the block and piston combination will not work.. - anyone looking at a cheap 25det block?
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3248658
I doubt it has been bored out 1 thou, 2 thou piston clearnace cant be right for the forgies, its just too small, they would sieze. 4 thou is only a little loose, why not just chuck it back together, it wouldnt have been causing the massive dramas that the car has.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249566
GTS4WD,
Try not to over complicate things.
Send the block in to be bored/honed WITH the set of pistons. The machinist will measure up the pistons and bore to suite your intended application. Obviously have a little discussion with regards to what the piston manufacturer recommends, intended use etc etc.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249624
GTS4WD,
Well im looking to put together a hi comp 25/30 NA project together.. so.. dont have much use for this..
But I may get the block sleeved and sell the whole bottom end off with the pistons..
Ill get a few quotes for getting it sleeved.. but I mean.. I seen a fair few 25DeT blocks going HEAPS cheap lately.. so Im not sure if its worth it.. but I will get back with you guys about it..
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249785
Those pistons will run .05mm or so clearance. They are not your usual forged piston which is forged from a billet, they are more along the lines of pressure cast. Being hypereutectic, the coefficient of thermal expansion is a lot lower than a piston forged from a lower silicone content alloy, so not so much difference in size from cold to hot. It would be a lot cheaper to buy a set of pistons than to have the block sleeved.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3250068
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
