i am in the process of making an alloy gauge cluster for my dash i will take some before and after pics to show you the procees i take. if you guys would like. might be over a few weeks as i will have to do it in my lunch hours but if you lot want to see i will be mo\re than happy to help you out.
this is me after 4 hours of polishing.
Edited by 18RZZ
  • Replies 49
Posted Images
Hahahah Ill forgive the photo because of the mass of experience you've written up! HAHAHA
hahaha
oh dear.
Cheers, might get some of the green compound bar and give that a shot.
I am using the bar type compounds which seem to be reasonably hard. now to find some time to get back to it >_<
I’m never polishing anything again, at least nothing as complicated as an RB26 inlet plenum!
I calculated around 40 solid hours to complete, and I didn’t even complete the bottom of it!
- Paint stripped it
- File finished the whole thing, casting marks, letters, deep pits from the sand cast
- Used the above mentioned “fan like” paper sanding drum on the end of a drill, with a small 1” one for between the runners.
- Worked way from 400 600 800 1000 grit. Then went straight to the stitched cotton buffing wheel drill attachment. The finer cutting compound was enough ( I think because I went right up to the 1000 wet and dry)
- Came out really good, I should post some pics up.
I would never ever attempt this again, unless paid an insane amount of money.
Iv heard ppl do a little each night in front of the TV, with it on their lap, but I prefer doing it wet, the paper lasts a lot longer and doesn’t clog.
Get some pics up Michael :)
Still not completly done and happy with it, but its not on the car yet. Will go over with 800 > 1000 again, then buff with compound.
In the end, its about time; the thoeroy is there, it just takes time. I couldnt get a sanding tool into between the runners, so its all about how quick your fingers repair from being sore and "finger printless" Just do a few hours every day and use the idea of the pictured product to keep the enthusiasm up haha.
Edited by GeeTR
lol i swear these forums are aj city..
i got half an hour into attempting to polish my gee reddy ripoff plenum before f**king it off today :laugh:
what do people usually use to get into all the nooks and crannies associated with plenums and more tricky jobs?
Dan
You Learnt That At Kamp-Pooka?
Didnt ya.
Andrew
  • 1 month later...
Haha Kapooka
I remember good ol pooks, go RAAC, shame we still had to polish the brass up.
We got busted taking a fan apart, sticking wet and dry to the fan centre and using it to polish brass - result: no fan for anyone, 40+ degree days, lots of sweaty nights.
I am in the process of polishing a stock plenum too...WAY too much work, but I have spent too much time to give up now.
i got half an hour into attempting to polish my gee reddy ripoff plenum before f**king it off today :)
I polished my new water pump today (only the top half which will be seen).
I used 400, 800 then 1500 wet and dry and then polished with autosol and a Dremel.
It came up pretty good. :P
After polishing this small part i can now justify the $300 i paid to have my custom stainless intercooler piping mirror polished ! :whistling:
Before
After
Here is some tips and hints etc for polishing that should become handy
http://www.caswellplating.com/buffs/buffman.htm
and here is a funny walkthrough for polishing bike frames
http://forum.caswellplating.com/showthread.php?t=1755
-snismo - that waterpump looks good
I picked up a spare crossover pipe for cheap so decided to have a go at polishing.
Deleted the seams on either side as well as some "unnecessary" fittings just to neaten it up a bit. Then gave it a once over with a 120 grit sanding disk using a drill to get rid of the really rough stuff, then by hand with 180, 400, 800 and 1200 (contemplated 2000 but CBA), then just polished it with some Autosol.
It's by no means perfect, but I'm happy enough, and it almost matches the sheen of the cooler piping.
Haha Kapooka
Pooka is Pooooo, we polished our brass everyday, and didnt even get the use it for march-out!
oh well typical army f**k around :)
wow! all the peices looks really good, i was going to get into over the uni holidayz and i think i just might looks like alot of effort but well worth the finished product (i hope) i going to buy a small bench ginder tomorrow (it is 125mm, 150watt, is this too small)??
Edited by H@ME
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
