  • Replies 67
theres a place called cut lunch that i go to everynow and then, dont know where it is off the top of my head, ill find out later, but it might be worth considering for a SAU lunch.
Edited by scandyflick
SADLY!!!!
I wont be able to make it, My car is going into Jack Baker Tyre Power to get rims at 12 and I have to cover my boss who is arriving at 2pm.
I can't squeeze it in unfortunely, hope you guys gave a good lunch.
Yes Paully, all the happy ladys can rape me if they want! I'll leave all the ugly ones and the men to you tho, Your specialty! :(
Are you trying to get me to come out of the closet and then make myself available to you Deluxe? You know my specialty is chicks with tatoos on their lower back.
No Paully as i said "the ladys can rape me" BUT if you want to come out of the closet....... Thats entirly up to you!!!
it looks like without me this event is a shambles. in 2 weeks I WANT AS MANY PPL AS POSSIBLE for the next place, me and fishpaste are counting on u.
I was thinking Ding Hao's for yum chao. dunno. make some suggestions.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
