  • Replies 843
Posted Images
Never truer words spoken Adrian. no.7 is a pet hate of mine. Despite what paul say's,
THERE IS NO SUCH THING AS A "BOLT ON' MODIFICATION.
bullshit...buy big $$ brand name jappo gear like i do and you will never have a problem. My last 3 turbo kits have all been HKS and have had every nut bolt washer and bracket to install. No extra engineering required and were bolted on with my trusty 10-12mm Honda Mower offset ring spanner. That spanner has just about rebuilt my whole car!
Relied on an aussie to supply one piece of pipe in the latest build and could have walked to Trust HQ in Japan and back ive waited that long for it. Sometimes the expensive option is always the best as it saves time and headaches.
Edited by DiRTgarage
GO GO GADGET......MOWER SPANNER. :(
my mate who helps me with the car lost it once....i was livid...lucky for him it showed up (sitting on top of the front subframe)
i always clean it after every job and it has a special place in the top of my tool chest. :(
I need crew for tomorrow night. Who's keen and good with a spanner/wheel brace?
Mower spanner experience preferred but not essential.
spanner just came out of the parts washer and is ready for action...what time?
i agree that a good quality kit is much less of a headache to fit, but some cars are shit to work on regardless. i replaced a set of low mounts on a 33 gtr last week. used some manifolds with a balance pipe on top so had to fabricate water feeds, also fabricated oil feeds as the hard pipes are a mongrel. after 2 days of f@%KING AROUND I WENT HOME AND TOLD MY WIFE I DIDNT WANT TO DO THIS ANYMORE. im closing the shop at the end of december. from know on i am only working on nissans with chevs in them. you can all jam your 300s, gtrs, gtirs etc. funny that nissan build the best sports cars but also the worst to work on. i now agree with he mentality of other shops to charge like wounded bulls to work on these heaps of sh$t. charging fairly never got me anyware. the day of the modified street car is dead as most shops cant be f@cked and people wont pay the money the job is worth, unless your from sydney where it seems you can charge anything and people pay. plus cops are sending everybody to EPA testing. looks like dedicated track cars are the go and people will be doing there own work. thats my rant and before you ask, yes i have had a few beers.
Lets just hope the predicted thunderstorms and rain are finish by morning so the track is dry (plenty of thunder and light rain atm). If not drinkies at benm's till the early hours.
Edited by benm
It wont run a 10 tonight PaulyD. It's only on its PULP tune and no boost. This is just to sort out any gremlins. Would rather do that at 120mph than 140mph.
Stu - 9:34 and you're peaking. LOL!
sounds gay...im out :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
