Recently she has been missing quite a bit of mid range.
Initially I thought it was a new set of plugs I had recently installed then maybe a bad batch of fuel but no.
Near the firewall on the end of the fuel rail there is a fuel pressure regulator as there is also one at the other end near the radiator where I have the fuel pressure bleed kit installed.
There is a vacume hose that attaches to the fuel pressure regulator so that it can see boost etc.. The hose was totally nackered, big split etc etc.. So I replaced it. The fuel pressure reg gets it source from the same hose that plugs directly in front of the throttle body.
The mid range is now back with the same top end.
What does this first fuel pressure regulator actually do?
I thought only one fuel pressure regulator was required to regulate how much fuel is let back to the fuel tank.. Hence if you block off the return line then fuel pressure will skyrocket.
https://www.sau.com.au/forums/topic/17746-why-2-fuel-pressure-regulators/
Here's a pic that was taken a little futher back that shows the AAC Valve (Idle Control Solanoid) and the vacume hose that runs to the fuel rail (fuel pressure reg)
I should take a pic of my injectors as I have never seen them on another RB20DET.. Apparently they are C18DET Injectors.. Tilbrooks said they are not stock or standard injectors.
Hmm, interesting................
The reason why people have 2 FPR's is to allow sufficient capacity for the fuel to flow back to the tank. This is used when really big fuel pumps (usually 2) are employed, together with 1/2" fuel lines. One FPR is simply not big enough to return the excess fuel from this big a supply system.
The second, and more common, is to allow even fuel pressure and flow to all 6 cylinders. You feed fuel to the centre of the rail and have an FPR at each end.
Another is to allow for failure of one FPR, although I have never been able to see the logic of this one. If an FPR fails, it normally reduces fuel pressure, so having a backup would make no difference, you would still have low fuel pressure
Does any of this apply in your case?
Would any one have any links for pics of the RB20DET that possibly show fuel rails etc etc..
I've been googling but have came up with nothing.
I've just had a thought. Why is it the FPR towards the front of the engine reads from the Plenium Chamber but the rear FPR reads from in front of the throttle body?!?!?! :P
Forgive my ignorance if I have got this arseways,
I have 2 FPRs on my car - the stock one and an after market 1:1.5 adjustable one - the people who put it on explained it to me this way:
The FPR regulates fuel from the exit end of the fuel rail - if you put a more restrictive FPR in line with and after the stock FPR, then you get the increased fuel pressure in the rail, and the stock one just stays there and does nothing.
The reason they didn't take it out was because it was a fiddly job and it didn't matter that it was still there ( I took this to mean that they couldn't be fcuked)
This may not even be close to why you have two Joel, but I thought I'd add my story anyways as it may be pertinent in another case.
Again, if I have got my facts wrong, please advise, cause I am just going on what I been told.
Cheers,
I have a R33 and it and all others that I have seen have two FPR's
one on the inlet of the fuel rail and one on the outlet-return to tank,
I belive they do this to stop fuel presure hammering the lines and injector rail.
So maybe its factory or fitted to prevent this problem.
Regards
Damqik
yeh i just checked the rear one allows fuel into the rail from the fuel filter, and the front one returns fuel to the tank.....
seeing as the rear would see slighty higher boost (due to boost signal coming from in front of throttle body) and always flow more i guess the front one will actually do the fuel pressure regulating??
(i think from the way its plumbed, rear one increases flow as boost increases, and front one decreases return flow as boost increases)
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
