Got my car tuned on tuesday, very happy with the results :)
Mods are:
Front mount
pod etc etc...
Wired my a afc neo myself, Got Anthony at TURBOTECHNICS to tune it :)
Very helpful bloke and friendly to deal with!
Made 215rwkw on 8psi :D These neo afc are worth there weight in gold 40 horses at the wheels straight away :D
Is this a good result?
What mods next?
Edited by brizzi
https://www.sau.com.au/forums/topic/177505-so-what-should-i-do-next/
are u sure? sounds very high for 8psi?
what engine? got a dyno printout
either way it sounds good, the main thing is how does it drive, compared to previously thats the main thing
if it flies, then all good
Thats an awesome result man, on just 8psi.
What do you use the car for? Like do you use it on a track or anything or just as daily/weekend driver? I gues it depends what you use the car for and what you want it to do, thats probably the best way to work out what you need/want to get next.,
How about some suspension and get it handling good, so you can make some good use of that 215kw! :D always a good modification!
Thanks,
Abu
Edited by abu
What mods next?
i don't understand.
your car is what you want, so what do you want out of it?
more power? better handling? better fuel consumption? traction? drifing work? ICE? autosalon styling?
don't just do something cause someone tells u.. do it cause its what YOU want.........
post-27527-1185003783_thumb.jpgDyno sheet;
Wow - dyno's aren't hard to cheat did he have a full weather station to enter proper baro, humidity and inlet temps? Did he strap it to the dyno - what gear did he run it in ect etc - 211rwkw on 8Psi = bullshit. f**k me forums are full of shite just read the rb30/26 or 26 hydrid pages spoolup hit it on the head the amount of horse power some people are caliming is absolute crap. All this claimed power should be compaired on the same dyno the same day just to put the bullshitters to bed - the problem is they never seem to appear!!! How funny!!
Edited by rob82
Man, the B######T you are goin on about is un called for :D
Just because a few people have the tendancy to bullshit about supposed dyno results
doe's not mean you need to categorise the honest people on this forum.
well not that its reveal its a 25t neo that changes things a bit
the figure is probably normal ish and seems ok
i guess most people thought it was the stock rb20
i wonder what diff gears you have
what rpm are you at when doing 100km in 5th
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
