hey guys, just wondering is it hard to put in a short shifter urself..is it an easy DIY job or will i need to take this outside?..if can b done at home can ne1 provide me with insturctions on how to put in a short shifter 4 an r33?
thanks!
https://www.sau.com.au/forums/topic/177633-short-shifter/
i put in a genuine Nismo short shifter into my R32 the other night; did it easy in 15 mins.. mainly problem is getting the rings off that hold the shifter down in place; you need a special tool but i use flat head screw drivers;
after that it was easy; pull out stock shifter, put in short shifter, and i used the bracket that came with it to keep it in place; no chance of getting those rings back in ever.... lol
i didnt think there was a tutorial in here? dang, well i did alright then lol
https://www.sau.com.au/forums/topic/177633-short-shifter/#findComment-3250374
Anyone had any experience with the $60 e-bay ones?
I put of these in my 33 recently, you can reffer to the tutorial thats on here even though its for a C's kit
The only problem is that you have to get a genuwine bush from nissan for the bottom end of the shifter ($11 from nissan) because the supplied one is no good.
https://www.sau.com.au/forums/topic/177633-short-shifter/#findComment-3250486
  • 4 weeks later...
i had to put a ebay one in a 33. we used bits off the stock shifter to make it work (the bush at the bottom and 1 half way up). it was a bit of a pain to get in. i personally don't like it. the throw is too short and harsh. i persoanlly think there is no need for one on a skyline. they are short enough. if you want it a bit shorter and don't want to spend the money just cut the top off you stock shifter. it will have the same effect. shortening the top has the same effect as lengthening the bottom.
https://www.sau.com.au/forums/topic/177633-short-shifter/#findComment-3302775
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
