Well just got some more info, disconnected the wastegate pressure line. Car is free-boosting to 15psi (funnily enough what the actuator spring is set to) then boost tails off in much the same way.
ie must be the actuator....next question wtf can I do, what other option do I have for an internally gated turbo?????
  • Replies 81
Posted Images
Keep on winding the actuator up more and then going for a test drive. And if you've got an ebc that supports rpm based boost control you could overshoot the boost level where boost starts to drop off i.e. instead of aiming for 15psi where boost drops, aim for 18psi, it might average off to 15psi.
New theory!!!!
For the actuator to be forced open, there needs to be some pressure up against it ie one side is a much higher pressure than the other side.
OK my dump pipe is 100% split, so the exhaust is about 2" in diamter and the dump has it's very own isolated 1" pipe....I'm thinking maybe the pressure across the actuator side is getting too high for the exhaust flow that the car is trying to push.
If I just threw a bellmouth dump pipe on I'd probably be better off as there is no chance of a pressure difference across the internal actuator as it's also seeing the pressure from the exhaust flow (unlike now as it meets way down the pipe where the exhaust pressure pretty low in comparison)
Feedback please :D
Feedback please :D
You maybe right about the dump pipe being to small. Back to back testing on a neo stagea with a hks gtrs, which would be similar size to your hiflow, a bell mouth dump got 7rwkw more top end over the split dump pipe. The tuners believed the difference was caused by the split dump being too small.
Pm AFRO, he has a spare R34 GTT bell mouth dump for sale, or he may lend it to you. He lives at Rochedale
You maybe right about the dump pipe being to small. Back to back testing on a neo stagea with a hks gtrs, which would be similar size to your hiflow, a bell mouth dump got 7rwkw more top end over the split dump pipe. The tuners believed the difference was caused by the split dump being to same.
All over it like a fat kid on a smarty!
A CES HPC-coated stainless-steel split dump is coming to a "for sale" thread near you!!!!
A long time ago I made a split dump for my R33 and only 3-4mths later everybody was making one.However I regret not making a bellmouth as I truly believe they are better.So yesterday I removed the split and replaced with my own bellmouth.It will go in to the hitman next week for a tune so should be interesting to see the result.If seat of the pants are anything to go by I`m right ,the power is much better up top.Doesn`t seem as crisp down low but remember ,no tune yet.
I dont think a bellmouth will make any differance !!!my .02
Why not? It makes sense as the pipe running behind the actuator is at low pressure with respect to the exhaust side, that's the only way it can be pushed open.
Bell mouth will equalize the pressure as there is no difference accross it then.
By saying you are using a bell mouth dump pipe you are essentially implying that you want the wastegate and the turbine exhaust exits from the turbo to be contained within the same inlet chamber of the dump pipe, right? Unlike the split where there is the two seperate paths. If so without the split i think you may be right, as the difference 1" vs 2" diameter can (and i emphasise can) make is a good point. The single exhaust chamber in the combined dump pipe, will ensure the pressures are equal!!
Hope the change of dump pipe solves you problem, look forward to hearing the results.
Eactly dude, that's what I'm going with...see dodgy picture :D Equal pressure all the way! I think the split may be a good idea with a stock turbo, but my one is realy trying to push some serious gas out of it, the split just isn't working methinks.
Im a noob but will bet 1k on it that it doesnt help at all.
I have a bellmouth.
to hold 15 psi ur reversion may be anywhere in the flow path even inlet :P
dyno chart tells you u were fine at 10 psi ,maybe a leak after that?( i put clamps on all my hoses)things like orig boost guage may leak?
I could be wrong also :D
but ur right i dont like split dumps idea anyway but a split may have less presure on the exhaust side being seperate from the main exhaust presure?
u want less presure behind the flap and more pushing it open
like someone said bleed valves will taper off too if ur running dat
I have a bellmouth.
Yeah but inlet restriction doesn't push open a free-boosting actuator, the pressure was enough to overcome the HKS actuator set at 15psi, currently I don't need to run any pressure lines to it to make it open...no boost control whatsoever.
$1000 would be nice :D
I was getting overboost and underboost mixed up :D
But im just trying to help!
****new theory!****
maybe at a certain point the exhaust where it meets the wastegate pipe will make the small wastegate pipe have vacuum!thus forcing the actuaotr flap open more than you want at high gas speeds....thus bleeding your boost off
how big is dump pipe it only looks 2 1/4 inch?or so..
but i still think split dump is not the prob :P
the bellmouth might make a difference but if i follow what you're saying correctly, i don't think it will make it for the reasons you're suggesting. remember the whole reason we use splits to keep the w/g and exh seperate is so the w/g flow does not impede the exh flow. there is no turbo system that i'm aware of that uses pressure from the exh to keep the w/g closed. this would also suggest that when you are at wot the w/g operation woud be compromised by the exh gas flow by not letting it open.
the w/g is controlled by the actuator. the preload might be too low and be allowing some creep or there might be another issue with the intake side, but i guess you've checked thoroughly for obstructions etc? it would be unlike CES to make something that's not functional, unless the gas you're pushing through the hi flow is exceeding the capacity of the exhaust but they seem to be switched onto that sort of thing. also have you enlarged the wastegate orifice? can't speak from experience on this one but apparently some turbos with hi flow etc will exceed the capacity of the standard size wastegate.
good luck, intersted to hear how you get on
just saw your post re no w/g lines needed to make it open - now i reckon definately check out that actuator.
Edited by Scooby
Yeah that's why it may be easier just to go to the bellmouth, equalize the exhaust and wastegate side and be done with it.....you really don't know how close I am to getting an EVO lol!!!!
A greater spring tension is just going to see me pushing more boost than I want to with the current gearbox....aghghg why can't things be simple!!!!
Yeah I went down to CES for a chat about it all. But maybe that's the issue, the setup is awesome for a fairly stock turbo, but once you get the exhaust pressures moving it's enough of a pressure difference to open the wastegate...we're only talking 15psi of load which in the scheme of things isn't much when you consider the pressure at the turbine.
I'll put a bellmouth on, then we can reconvine and discuss :D
Just so you know I have no problems with power or holding boost.The only reason I changed the split pipe to bellmouth is as an experiment because I`m a hopeless fiddler.But think about it,when the wastegate opens the only time the gases are not going in the same direction is when the flap STARTS to open.Thats when the gases are going sideways but only till the flap opens further then all gases are going in the same direction.Plus the Fact that the standard or high flow turbo is quite small in the turbine outlet area,putting a restriction in the way via a divider is causing more problems than it solves.Gas wants to expand when it is hot so why would you stop it by keeping it in a 2" pipe? Don`t forget,the wastegate opens after boost has been reached so the turbine will boost faster with less restriction via a bellmouth.Realistically,the turbine dump pipe on a high flow should be a 4" pipe to ,say,the rear side of the cat.Now that would be efficient at 20lbs of boost.
I remember a published experiment years ago involving a V8 holden and going from twin pipes to a single.The single gained some 15kws due to all the gases in the same pipe speeding up the gas flow.Just a thought. :yes::blink:
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
