I'll be pickin up my new R33 GTS-t later this week and would like to do my own mini self service soon after, how’s this sound:
- Oil change (Fully synthetic? Something to accommodate freeway driving?)
- Oil filter (145a)
- Clean air filter
- Fuel injectors (metho?)
- Fuel filter (z200?)
- Coolant
- Spark plugs (NGK .08mm)
- Octane Boost :-)
- Reset ECU
- Then a Tune
Anything else?
https://www.sau.com.au/forums/topic/17792-r33-gts-t-newbie-self-servicing/
I just got my R33 on Friday, anyway upon inspecting I found that the compliance place had already done most of these things.
New Fuel Filter
New Air Filter
New Oil Filter
Changed Oil
Changed Coolant
I haven't checked the plugs as yet or the fuel injectors and I reset the ECU myself wasn't sure on that either.
You might find that a lot of it has been done for you.
I'd check/replace your gearbox oil too. Maybe even your diff oil.
I know my gearbox oil wasn't changed when the compliance was done, even though it should've been :cool:
And maybe take your AFM off and give it a clean too. There's a thread in the Maintance section about that.
Cheers
J
Sorry my post may have seemed a little misleading.
Its not a fresh import, I bought it locally.
90,000 kms on the clock.
Is gearbox oil an easy job? My servicing experience extends to Oil/Air filter changes & brake calipers.
Plugs?
Timing belt at 100,000kms I spose?
Guest RedLineGTR
prob do it now...unless it has been done before but i doubt it...but it's worth doing just just incase it is getting worn and you rather use the money now rather then it snapping and destroying nearly everything
Guest RedLineGTR
the items that he's changed...find out what he has and has not at least you will get some history..what oil has been used when wa sit last changed...make sure you check out if he can provide import papers...of some original documentation..some original details..
theres alot to do here, first dont use metho on ur injectors,
make sure u use the correct coolant, nissan coolant is good, u shouldnt mix coolants, if ur going to flush the system make sure that u do put to much coolant and not enough water, u have to get ur mixtures right
how do u plan to tune it, u need a computer to give u diagnostics on how the car is running
and u should make sure u do ur timing belt if it hasnt been done, its a big job, call around to a workshop and see how much they will charge, because u dont want things to go wrong after, its a lot of money, they will be able to tell you what needs to be done and what doesnt, ur skylines at the turning point of its life
make sure the workshop are skyline specialists
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
