Hey guys,
Im thinking of selling my beloved GTR to try and force my way into Sydney’s home market.
I would like 30K or a swap with something of interest. What ever I consider it needs to be reliable.
THE CAR:
Black R33 GTR VSPEC
65000ks
cat back exhaust
duel pods
original GTR floor mats
original GTR front and rear strut braces
turbo timer
17 x 9 inch 3 piece OZ RACING rims
brembo breaks
immaculate inside and out
well looked after with no stupid mods, she was fresh of the boat at the beginning of this year from Edward Lee’s. Should still have 10 months warrenty left if Edie allows it to change owners.
PIC’s
Edited by dave b
https://www.sau.com.au/forums/topic/177978-r33-gt-r-v-spec/
Hey dave, I'd be interested in a few more details as well.
Please post up some pictures if you can or PM me.
Also I'd like list of modifications (if there's anything more than what you listed above), powerfc, suspension, tyres/rims, etc., what year, body kit, ...........
thanks heaps :fakenopic:
https://www.sau.com.au/forums/topic/177978-r33-gt-r-v-spec/#findComment-3248436
hey buddy im in sydney
depends what your 34 is like. Kms, doors, trans ect
i have a 2door silver manual done about 78thousand kms, lowerd with superlow king springs, 18'' starcorp rims ,custom turbo back exhaust, blitz lm fmic, blitz sbc id3 boost controller, blitz lm air filter tuned at 8psi 188kwrw ive only had the car for about 6 months and bought it completly stock
https://www.sau.com.au/forums/topic/177978-r33-gt-r-v-spec/#findComment-3310316
PM sent
https://www.sau.com.au/forums/topic/177978-r33-gt-r-v-spec/#findComment-3313224
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
