I had the AFM fail a couple of weeks ago (intermittent engine cut, 10.5:1 AFR) and finally replaced it last weekend.
Car was running fine until Thursday when it had a sudden power loss for an instant, which was repeated yesterday on the way home. When I stopped at home it stalled and on restart the idle shot up to ~2k rpm. Left it overnight, and had a play today .
- ECU is showing no new faults.
- On startup the idle shoots to 2K rpm, AFR at 14.7:1 after about a minute
- If I disconnect the AAC the idle drops to normal.
- Once fully up to temp, the idle drops back to ~ 900 rpm (after say... 6-7 minutes).
- If I restart the car again, I'm back with the 2K rpm idle.
- temp sender appears to be O.K. (I tried a spare).
- Under boost (~13psi) AFR is 12.2:1, which is around what it used to do before the AFM replacement.
Any suggestions? The ECU is an RB20DET manual ECU (supposedly anyway - it's a 23710-04U00), but the loom (from an auto) isn't fitted with a Consult plug (although there is a connector which has the appropriate RX/TX wires running to it).
https://www.sau.com.au/forums/topic/178447-2k-rpm-idle-on-my-rb20det/
Ah - the TPS! I've had intermittent TPS errors for years, so hadn't bothered to consider that. But that's what the problem was - the idle switch wasn't closing properly anymore. Quick adjustment, and now it's all working correctly.
awww no fair, wish mine was that easy.
the idle shot up another 300rpm after i put some cylinder cleaner through it. Perhaps carbon deposits blocked the leak a little
Its easy to engage the twin plate with the higher idle..thats about the only upside i see lol
Oh well, its getting fixed next week :D
  • 1 month later...
to fix the tps you undo the adjuster screws just enough so you can adjust the angle (clockwise/anticlockwise) of the tps until the idle is right. But be careful, theyre only minor adjustments and if you move it too much then it might take a little bit of fiddling to get correct again.
you can check the TPS signal as being 0%( or volts?) as correct on a Power FC controller or if you have a consult cable
your resting tps volts should be between 0.3 and 0.4 volts. any less and you get this lag effect, any more and your car revs higher. and the wire to test is on the plug attached to the small length of wire coming out the bottom of the tps, not the one on the side. thats your throttle on off switch.
its the middle wire i think, one will be ground, one will be 5v and the other variable (thats the one).
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
