Installed mine two weeks ago, noticed a massive difference in low down torque compared to my remap by AutoSports Engineering.
Excellant value for $150 I must say.... Will get the car dynoed soon to see how much power it is really pushing out.
I'm interested in the remap, at the moment on my R32 I have:
3" turboback exhaust
Stock cat (gutting it or putting in decat pipe.. need to visit exhaust shop as bolts are stuffed)
FMIC + POD
Stock turbo @ about 12 psi
Have a fuel pump ready to throw in.
I'm not sure how much power I'm making, though its not very impressive. I hit fullboost at about 3500rpm, when does this tune? and what boost is it running?
Is the reason for the lower rev limit because the turbo's running out of puff up top?
And is there any real difference between the Rb25 and neo turbo's? All I've heard if rumours .
FMIC + POD
- Stock RB20DET tune is extremely rich
- It's tuned for 14PSI, but I'm game and running 15PSI :)
- Rev Limiter in place to prolong life of motor
- RB25DET = steel compressor wheel
- RB25DET NEO = Nylon compressor wheel
The remap did next to nothing on my RB20.. the power curve and afr curve were identical (did back to back runs on the dyno), but I did gain an extra 5hp at the top end.
Also the valet mode map switching didn't work.
On the plus side, limits were removed which was great as when I put the RB30 in it just hit R&R all time. RB30 is now running quite nicely on the remap from CEFFIE due to no R&R, so it wasn't a total loss :thumbsup:
Also because I had a cradle fitted to the spare ecu, that's $200 I save off my tune/remap next week :P
If I didn't get this remap kit, I wouldn't have been enjoying my twincam 30 for the last 2 weeks :rolleyes:
  • 2 months later...
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
