Forsale: Rb26dett - Sard 800cc Injectors, Tomei Procam In/ex 260 10.8 Lift, Tomei 1.8mm 88mm Bore Gasket Kit
Hey,
Got a few parts for sale which i was gonna use for some of my car but change of plans as the price keeps building up. More parts that i bought over a few months will be up as well soon.
Item:
Brand New set of SARD 800CC RB26DETT Injectors.
Price:
SOLD
Item:
TOMEI PROCAM IN and EX
260 Degrees, 10.80mm lift
Condition:
BRAND NEW - Sealed Packet
Price:
$950 incl postage to your door.
DROPPED $850
Pics:
Item:
TOMEI Complete Gasket Set.
1.8mm, 88.0mm Bore
incl: metal head gasket, metal intake manifold gasket, metal exhaust manifold,
metal throttle gaskets, oil gallery orifice.
Condition:
Price:
$500 + Postage and Handling
$450
Pics:
Edited by Owgasm
$1.25 cash :P
thanks for your rubbish posts all through For sale. you have earned a warning increase and 2 days moderator preview. Next offence is BAN.
Shift performance is selling
Tomei RB26DETT GTR Gasket combination
Product Details...
$470.00 (including 10 % tax)
which is new still cheaper then wat your selling it for
@ www.shiftperformance.com.au
Edited by GT King
  • 3 weeks later...
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
