Wrecking my R32 GTS4 89 model.
Hit a gutter and screwed up underneath the front end of the car. Do not ask if it can be repaired as its not worth it.
I would rather sell as whole cause i really cant be bothered - $4000.
Main parts im willing to sell are as follows, however, there are many other small parts just tell me what u need.
Im located in Bonogin on the gold coast. I am prepared to take some of the shit off myself but most of the shit u will need to organise yourself.
* RB20 - 70,000 ks - would prefer to sell with gearbox, wiring, turbo, etc. Will sell with stock cooler for $2000 o.n.o. or $2300 with front mount kit.
* Blitz SBC spec s electronic boost controller $300.
* Blitz pod - $80.
* Rear tail lights - make an offer.
* Interior - make an offer - slight bubble in dash (will remove if someone is interested).... slight damage on drivers side seat. Everything else is good.
* Rims - like the ones in the picture, however i have another complete set which are basically brand new with tyres (Front 90% Back 60%). $1000.
* LSD - make an offer.
* Windows - front has a crack. all the rest are good. make an offer.
* Bonnet - make an offer.
If you need anything else let me know and make an offer. pics are below.
cheers.
https://www.sau.com.au/forums/topic/178854-wreckin-r32-gts4-or-sell-as-whole/
* Blitz pod - $80.
cheers.
hey buddy
Just wondering if you have the standard airbox and snorkel for r32gts-t
cheers
  • 3 weeks later...
  • 3 months later...
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
