  • Replies 75
andy was too lazy yoo post lol anyone interested
sif i was lazy >_<
nah work has been busy all week
10pm is too late for me, gotta work Sats, last week came home nearly 2am killed me the next day
perhaps 830 meet @ the same place? for a 9 departure
This sucks... Its torture reading the replies. I'm going to unsubscribe.
I was so looking forward to driving the car after 4weeks of it being off the road. Damn incompetent idiots. I should have known better though. :D
So on to the drowning my sorrows with a few CC's. >_<
So on to the drowning my sorrows with a few CC's. :D
You can ride with me if you have the balls LMAO >_<
Poor Cubes wish i had Spare GTR now lol :D ...but then again the misses would be driving it and i would be driving my gtst >_< So 8:30 then i had better get moving then lol If the meet spot changes Sms Me on 0415 549 709
Edited by Black_Vash
Well I would have but my turbo oil feed banjo pisses oil everywhere. >_<
So off to pirtek tomorrow morning for them to fix it as they f**ked it by putting it in their vice or what ever they did to damage the banjo face.
Didnt think they were open on sat ?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
