Guest V8r31Skyline
Question to Skyline enthusiasts, this may be a first but am having a few probs as i have just bought myself an R31 with a 308 donk and turbo 400 3speed trans, first major prob is vibration from the tailshaft and/or diff and yoke ,which would be the major cause of this be? as it still has the standard split tailshaft but there is more than an inch from the rear of the gearbox still uncovered. Next is just a minor prob ? is it correct that the instrumental panel ie speedo electronic and can it be run manually through cable speedo ?????? Help Me , once this baby is on the road properly and exterior is taken care of it shall be on the road ready to race all you other enthusiasts , previous records of this car down the quarter are 11.4 which it ran 2 months ago at willowbank
https://www.sau.com.au/forums/topic/17941-electrical-hiccups/
stock tail shaft?? dodgy CV joints usually cause vibrations. some ppl get a one piece for their r31s
the trans speed sender (also used by the ECCS for things like determine if to clean the AFM wire after a drive) might be able to be connected somehow where the normal cable in the other trans would to use the stock electronics speedo. but id imagine you'd have to gear it right to get it accurate
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
