Been happening off and on for a little while now, every now and then the engine will die, dos'nt stutter or anything just dies all together and then about 1/2 - 1 second later it comes back, always happened whilst i was driving untill the weekend, it would'nt start, cranked a few times and it wouldnt start, turned the key all the way off and 3 or 4 of the warning lights stayed on, i think it was the engine, exhaust and the usual alternator and one other one next to them, turned the key back on and it started.
As i said its been doing it for a while but it is doing it more and more often lately, nothing else dies just the engine and it dos'nt splutter or slowly die it just dies like someone had turned it off, all electrics inside work like normal and the only warning lights that normaly come on are the same ones that come on when you turn ignition on before you start the car.
If anyone has idea what this could be i would appreciate it.
Thanks.
https://www.sau.com.au/forums/topic/179622-engine-dies/
rb25det S1 R33.
The problem is that it is intermittent, cant really find the problem unless it happens whilst he has it, could spend a fortune looking and never actually find the problem, im hoping someone else has had the same problem.
https://www.sau.com.au/forums/topic/179622-engine-dies/#findComment-3276336
Simililar issue to mine except I lost everything... ended up being a crushed ignition wire running over the top of the steering column.... took a couple of days to find the damn thing and it only was a problem as a friend drove my car and moved the steering wheel from where its always been!
Could be many things....... i'd start with the ignititon circuits and start eliminating, your obviously getting the ignition at the barrel if your retaining reds so it would be after that which then eliminates out about 6 fuses that could be half on the way out! .....
Another possibility would be if you have an alarm and the immobiliser is playing up and activating even though the alarm isn't on..... guessing to would have ignition/spark & fuel cuts as standard....... have seen it happen but alot of the time the siren would activate also...
When driving, does it seem to be a bump or similar in the road that causes it to die or is it just random?
https://www.sau.com.au/forums/topic/179622-engine-dies/#findComment-3276373
Ive been trying to pin point when it happens but it does it at anytime, the first couple of times was when it was cold but now its whenever it feels like, also on the first couple of times it was at low speed but since then it has done it on the freeway, hav'nt noticed any pot holes and on the weekend was the first time it ever did it when starting, normally its always happened whilst the car is moving.
Its an odd one, i know its going to be something simple but where the hell do i start.
Actually one thing i found out on the weekend is that the ecu has no bracket holding it in, maybe there is an earth issue there.
https://www.sau.com.au/forums/topic/179622-engine-dies/#findComment-3276404
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
