gday y'all
im new here and wondering if i can get help around the place
im gonna buy a 32gtr, my brother and his mates say that i should get a commpression, leakage and all-round performance check with this car im getting
whats everyone else's thoughts on that?
i personally say, i have enough money for things that go wrong with it..
but im not looking to have this car at 600awhp, just keeping around 300-400awhp
cheers,
adam
https://www.sau.com.au/forums/topic/179661-hey/
You sir, are a fool if you think like that!
Get a compression and leakdown test done, for the few hunjy (if you have "plenty of money") it'll cost you it might well save you later, when the car forces you to spend "plenty of money"
Look in the consolidated workshop thread for a trusted workshop to help you out :P
https://www.sau.com.au/forums/topic/179661-hey/#findComment-3272104
haha
i hate murphies law, always happens to me at work lol
but doesnt matter really.. the gtr, me and my brother have inspected.. going back for another inspection soon
it drives like a dream, as soon as i get it, ill put a new oil pump, filter etc.. on it, do a basic engine upgrade to it, so new turbos, zorst, and what-not
lol, the reason im not importing is because they could say it has 20,000kms on the clock, immaculate interior and exterior, and you pay for it and get the car and its a bucket of snot
thats why im looking only around perth for a gtr.. and i found a perfect little one =]
https://www.sau.com.au/forums/topic/179661-hey/#findComment-3272199
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
