Ok just for your interest. Prices arent trade prices btw.
December 05 and onward Headlight Assembly is $1942+GST from Nissan for EACH headlight, including globes and wiring (no ballast resistor pack however)
Headlight body and Lense (no globes or wiring etc) is $1030ea + GST
Part No: 26025CM41A for the RHS and 26075CM41A for the LHS
Tail lights are a similar story if you want to upgrade to the nicer 06/07 model (looks so much hornier than 03!) They are $443+GST for the body and lense. you have to put in your own LEDs from you existing lights.
Part No: 26554CM41A for the RHS and 26559CM41A for the LHS
Frank, can you advise if we need to modify the wiring in any way, or is it simply plug and play? Same headlight globe size etc?
Thanks!
Jai
No modify required, simply plug and play. need a bit adjustment as those headlight come from US who is on the other side of road against us.
after installed, the right hand light is higher than the left hand, we must adjust them reversed as it may hurt the opposite driver's eyes.
Edited by Frank350GT
  • Replies 71
Posted Images
Hi there!
It's and added kit I'm pretty sure, but must have been done originally as was already there, so not sure on cost either.
I do know they are HID bulbs and there are balast units behind the bumper, also looks like a wire on each side that has been cut and taped up.
I'm yet to pull it all appart and see what's going on in there.
Will let you know for sure once I know ;)
Just got the price of that HID fogs, $1000+, man , you got such a big bonus.
Why spend $3k, as Frank said , he got his headlights for $250 shipped each, surely even after you've got all the bits and pieces you are still well under that $3k mark and they look like they are in decent condition.
I'm thinking of doing the same, but I have a 6000k HID kit I bought ages ago for my other car and never used them. They are H4 which had the high and low beams in the one bulb. Don't know if and how it will fit in but I'm going to be assessing it all soon.
Actually Mine is $250 shipped a pair included the HID bulbs, I used the ballast from old light, buy new sets of turing light and parking light from AUTOBAM sydney, who over charge me a lot.
About your H4 HID, you can fit them in the FOG/High Beam in 03 light, I done it with my 03 light 1 year ago. just need to cut off 3 wire ( yellow, grey and yellow/red ) in my memory.
Frank,
where did you find the lights for $250 shipped? Do you have a link?
So normally before the compliance, is the top part of the headlight unit the FOG/high beam is it? or is it the other way round?
The top part is Low Beam, with D2R HID. The bottom part is the FOG/High Beam with H4 on 03 Headlight.
On 06 Head light, Top part is Bi-Xeon, mean Low/High beam in same lense.
Bottom part is Fog(H1) and Parking light ----a very small bulbs on corner.
Are you still looking for the exchaust???
I thing US guys get a lot of HKS, with very sexy sound.
I was looking into the HKS a little while ago, and i think my car has HICAS which means the HKS won't fit. If anyone wants one the best price I found was around $1850 USD delivered to Syd.
The guy who's looking into wheels for me is bringing in a couple of Fuji exhausts in the next few weeks so I'll wait and see how they are.
I'm also waiting on a guy in the US to get back to me on the NISMO exhaust. Hopefully will hear today.
I also found a really good deal on Borla True dual, $1050 USD delivered to Syd, but I think this is too deep for me.
Cheers
Bobby
Cheers
Bobby
How does Fuji sound like, In my memory it is a silent exchaust, please tell me I am wrong.
About Borla true, do you mean the sound is deep?
I should search youtube to listen to that.
Thanks
I have the borla, it sounds porn. very much makes the vq sound like a v12. c-red in perth stock a few v35 exhausts
JK
Yeah i've heard some clips and agree it sounds like an eight/12 more than a six. I spoke to C-red a while back and unfortunately the price is much higher than what i would cost from the states.
Frank - yep the fuji is quite silent. I wanna keep the same sound as stock but louder, which the fuji does in the higher revs.
C-red have the full Borla Catback instock for $1600, maybe a bit less with a cash offer! Ive had a quick look over the net and Borla online is about $1200USD without shipping, online pricing about USD$900 without shipping - but the big pain is finding a company willing to go through the hassle of shipping here. most online stores wont! And shipping would run into about $150USD-$200 depending on who you use, so thats already getting close to $1400, and thats on a good day if it slides through customs!
JK
Edited by jaik
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
