Im looking specifically to buy these cars. Prefer complete original cars but will consider almost anything including parts and engines etc.
Give me a call on 0410 842 016 or [email protected]
Australia-wide fine but VIC, NSW and QLD are easiest for me.
Thanks
Drew
https://www.sau.com.au/forums/topic/180179-c210-c211-240k-280zx-wanted/
with body kit etc.there is a 3.1litre stroker TURBO 240k.
$3000 on ebay.....
fkn weapon it would be!!!
Seen it... an I agree that its pretty wild... but too much and not original unfortunately. More looking for grandma's old C210 growing cobwebs under a tree somewhere.
hahahahah....
Not a good idea asking that on a forum where people actually know what these cars are worth :(
Try local and asking people on the roads if they want to sell it. I brought my old smashed coupe buy knocking on their door and ive picked up a mate a datsun 1600 by leaving a note on the windscreen.
Edited by works 510
I recently picked up a 280ZX for FREE. Complete car and running all for the cost of the tow.
Done deal.
Ill organize a tow. Please give me a call on 0410 842 016 or get me at [email protected] and we'll sort the details.
Thanks so much,
Drew
yeh drew!
he was just saying what a good deal he got.....
i bet ya feel abit down now!
i have a set of GENIE III L6 extractors i got for $100 you can have for the same it you like?
the came of a carbie L26 powered 260C at my local wreckers....
yeh drew!
Right.... well if ghosty gets sick of it taking up space at the workshop, or he wants to part it out, he'll know who to call!
Ill let you know about those extractors too mags.
D
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
