Thanks for all the replys.
If it is clearance issues why does it change then? Its ONLY when it has been sitting still for a little minutte, it "binds".
Have measured accuratly today with a torque dial gauge. (built in dial gauge), range 0-8N. Its calibrated 2 times a year.
To break the "bind" it need ~6 N.
To rotate it need ~2N, after the "bind" has been broken.
If I start rotate just after stop, I still need ~2N.
If I wait 15 sec, it need ~6N to begin rotation again. (If I wait 5 min. it still is 6N to begin rotation)
There is NO spots were it need more or less N to keep rotation.
Have talked to a engine builder here in Denmark. He says when the crank rotates it draws oil on to the surfaces, 2N friction, when it sits still the oil runs back in the grooves, and crank makes contact with bearing, that is what I need to overcome?
The block is upside down, and havnt tryed doing this when block isnt upside down. Could this have any influance?
Tomorrow I should check for endfloat, and run out on number 4 bearing? What more should I check?
The crankshaft runs on a hydrodynamic wedge of oil which can be squeezed out when the crank sits for a bit and the crank sits against the bearing. Once you turn the crank you pull oil between the crank and the bearing and the crank floats on it. I'd still check the end float, most bearings are made at the maximum thrust flange width which can reduce the thrust clearance anyway. It's quite common to have to sand the thrust face of the bearings to provide the proper end float.
Cheers,
Greg.
Endfloat is: 0.08mm
Run out, measured on number 4 main bearing, is 0.015mm. This is total what the dial show. Souldnt this be cut in half to get correct run out number?
Edited by nissan200sx.dk
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
