hey guys just got my car dyno yesterday and before i had it dyno they notice that i had cooland leaking from the water pump. would i have to replace the water pump or just the seal?? if it was to be the water pump where can i get a new or aftermarket one??
https://www.sau.com.au/forums/topic/180615-coolant-leak/
hmmm, it really depends
if could just be leaking from the base due to a seal failure
or it could be that the shaft of the waterpump is rooted
if it's the first one, remove the waterpump, put new seal on it and put it back in, they have a pretty long shelf life anyway
if it's the shaft, then you'll be needing a new one, scope out forums, ebay and trade places where you live, I think i got mine for $70 last time I needed it, which wasn't too bad a price, but I guess I could've searched for longer and found a cheaper option
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283758
You basically use CRC or Selleys quick sealant:
There are two types both work fine:
Black one = most commonly used is Windscreen Sealant
Clear one = marine sealant
btoh are silicone, use a 2-3mm strip round the old gasket edges of the waterpump, make sure you scrape off all the old stuff, then put it on, bolt it up and leave it to dry for a few hours :nyaanyaa:
Then it should be as good as new, total cost round $10
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283903
Flash if your going to go to the trouble of removing your pump i would install a new item as its a lot of mucking around to get the old one off and new one on.
try just jap they have them in stock as many of the traders here will
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3283986
its easier to get a new pump, when mine was leaking i asked about seal kits and everyone said to replace the whole thing because the pumps are pretty cheap now a days
if you havn't done your 100k service yet it'll a good time to now aswell considering timing belt might have to be taken off also
dont just seal it up either.. do it properly and change it all
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3284098
Flash you dont need a gasket you will need to use a silicone based sealant which is applied to the water pump just before you put it in place.
Make sure the surface on the engine block is really clean of old silicone gasket, scrap it with a sharp edge then just before you place the new water pump with silicone gasket applied, give the engine block a spray and wipe with brake cleaner to get rid of any possible oil so the silicone bonds well.
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3288959
mate i am not sure about a GTS-T but if its anything like a GTR then dont do it unless you are sure of what your doing.
You need to remove the engine vibration dampener of the crank shaft, all the alt, A/C etc. Then you will need to remove the cam timing belt. If you havent done it before get a mate who has or a work shop manual as there i a little bit involved.
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3289335
ok i just did mine but one prob. there is like a tiny hole in the seal and there is coolant coming out like how water comes out of a water pistol. could i just put a lil dob of sealant to cover it??
https://www.sau.com.au/forums/topic/180615-coolant-leak/#findComment-3294538
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
