Hey all, I'm Regretfully stepping out of my Skyline into something more a little cheaper to pay off some debts.
Specs as follows:
YEAR/MAKE/MODEL
1997 Nissan Skyline GTS25-T Sedan
ENGINE HARDWARE
Nissan RB25DET Twin Cam Turbocharged 2.5 In-line 6 83000kms Serviced Every 5000kms using Genuine Nissan Filter and Mobil 1 Oil
ENGINE ACCESSORIES
Just Jap 600 x 300 x 76mm Front Mount Intercooler Kit
Blitz BOV
GReddy Profec B Boost Controller (Very rarely run at 11psi, usually switched off)
DRIVETRAIN HARDWARE
Nissan 5 Speed Manual
BRAKES & SUSPENSION
Front: Nissan(Sumitomo) 4 Pot Monoblock Calipers with Standard size RDA slotted rotors, Bendix Ultimate brake pads
Rear: Nissan (Sumitomo) 2 Pot Fixed Calipers with Stock size RDA slotted Rotors, Bendix Ultimate brake pads
Jaguar DOT4 Brake Fluid
G4 Racing Street Spec Coilovers with 20% softer inserts
ROLLING STOCK
STREET
17"x7.5" Nissan R34 GT-T 6 Spoke Alloys
225/45ZR17 94W Falken FK452 Rubber - 2 need replacement
BODYWORK
Standard Nissan Sonic Silver
Front Bar modified to fit FMIC
INTERIOR
Stock Interior
Leather wrapped steering wheel
Nismo leather gear knob
STEREO COMPONENTS
Pioneer Bluetooth CD Player with Ipod adaptor (keeping that for my next car, will be fitting another unit or reduce the price accordingly.
Stock Front speakers with Fusion Tweeters :S
Pioneer 3 way 6x9's
PERFORMANCE
1/4 Mile 14.2@ 98mph @ WSID
156.4RWkW (using Dyno Dynamics Shootout mode)
I am the first Australian owner since buying it off a compliance workshop in November 2006. Its been nothing but a pleasure to own, great car to drive, especially on the open road. Every thing that u expect feature and performance wise from a Nissan Skyline with the ability to take the family or friends along for the ride! Am willing to remove certain items (Boost controller)
Rego till 20 November 2008
Chasing $15500, Headunit will be removed and a new headunit will take its place or negotiate without stereo. This is a Genuine and regretful sale. No Timewasters, no Joy Riders and no Test pilots please.
Will Trade for cheaper car/ute or 250cc motorcycle plus cash.
Bump. Regretful Sale. Price seem a bit high? I'm trying to filter out time wasters and low blow rediculous offers.
Forgot to mention, no joy rides, test pilots, timewasters
BUMP! Now on carsales, Mention SAU and I'll be more flexible on price, really want to sell it to someone who will look after it as much as I have.
Link: http://www.carsales.com.au/pls/carsales/...icle_id=4601620
  • 4 weeks later...
  • 1 month later...
Update: Price is up to $16750 as i have renewed the Rego for another year!!!
Wil Consider trades for S13 180SX with SR20DETplus cash Adjustment or straight swap N/A R34 Non turbo manual coupe
  • 1 month later...
Massive Price Drop! $15500, willing to trade for cheaper car/ute or 250cc bike plus cash.
needs 2 front tyres as they have camber wear.
Circumstances have changed and it MUST GO!
Come on guys/gals, surely you know someone after a clean well maintained Skyline, mechanic owner. This car has never let me down, need to sell so i can move out of home.
Make a reasonable offer. tell your friends, its a great car, but i wanna fulfill my dream of owning a Zed and i have a motorbike on the way.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
