I have some bits left over after selling my R32 (new owner has neglected to come and pick them up)
Parts are:
bare dash - good cond (no gauges, switches or anything like that)
Steering rack
power steering pump & resevoir
Steering column
I picked these up off a guy doing an RB20 conversion into another car, who did not need them.
I'm open to offers on all of the bits - just want to clear a bit of space in my (tiny) shed.
PM me for details, or e-mail me [email protected]
I'm on the Gold Coast
https://www.sau.com.au/forums/topic/18076-r32-gtst-bitsn-pieces/
  • 1 year later...
Wow! I'd almost forgotten about this!!. Still have the bits, will dig them out and have a look, and email pics to those who've requested.
Riverside - I recall it was in good condition (wrapped in rags at the moment). Best if you come and have a look at it. If you're keen, we can talk about pricing (translation: I have no idea what it's worth. I'll do some research ask for a fair price. Not out to make a million on it)
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
