I am looking to purchasing SK's bilstein shocks and whiteline springs for my r34. I am wondering if any1 here could give me a ride in their car that has SK's setup? i will shout them a Name IT meal from maccass LOL
can be in a 32 or 33... tho i prefer r34
cheers,
:laughing-smiley-014:
Make it a big mac meal, and buy me an R34 with an SK setup and you've got a deal!
