Hey guys,
Just bought an intake pipe off a bloke on here and it has no entry for the bov (which is fine becuz i run no bov) but i realised there is another feed that goes intake the stock intake pipe which appears to be for oil? (i really am unsure of what its for), the intake pipe i bought also doesn't have the entry for it, just wondering whether i should get a hole welded in or whether i can just bloke that pipe up? pretty keen on an answer tonight so i'll know whether to put it all back together for work tomorrow, i've attached pics
Thanks in advance for any help
https://www.sau.com.au/forums/topic/181005-intake-pipe-question/
u run no BOV?.and fresh air in crank will make oil last 4 times as long that all i know.only drag racers or d1 guys would not run crankcase vent (and some tests have proven it less stress on cranks turning)(and blowbye on rings)and with no crankcase vent u will deff need to change oil every 2000kms or less
and your car look daily driven so i would vent crankcase :( IMO
Edited by cosworth1971
soz for the stupid question but what does that mean lol? is the crank case the pipe that goes over the rocker cover? so i just take the pipe off and leave it open(the one goin to the intake)? is it generally the thing to do? any down sides etc?
When i say i run no bov i mean the bov is blanked off (flutter etc)
why wud u blank the bov off for?bov makes it boost faster!
and to run without the crankcase ventalation there wud be stupid and fatal that intake is for someone who changes oil every 1000 kms do you want that and more wear?
u need that pipe to make u engine last a long time!eg 100000kms vs 300000
yes u can run without it and leave it open but thats very bodgie i think!
with my rally car and webbers i run without but thats a full race car
yeah !wont hurt
I want someone elses view on this as the motor has a pvc valve near the left of that (near intake manifold/fuel reg)so maybe that enough?
so maybe u can run without?its just a question on how quick you oil get dirty as less air mean dirty quicker
Ive only had my car for 2 years but im a good old school motorsporter
you should try without?but then u may need oil catch can because oil may splash out those holes on the top of the motor?( i mean a little oil no heaps)but enough to be anoying.
i need more skyline expierence here guys
so dont drill yet mate
I'm not sure what you mean BAMR33, i wont need an inlet for my bov, only the other inlet which cosworth said was to vent the crank case
Can i the crank case vent be tee'd up to an oil catch can? because that might be an easier option rather than getting a inlet welded it
I only read the first bit of your sentence. But for your oil breather just disconnect it at the top bit of hose and put on a small oil breather filter thing, monza makes them and they cost like $10 at supercheap, look stock too. If your car is highly modified and having oil issues a catch can is necessary until you fix it.
what ever u do dont block it up but in older motors u can run a hose(the hose that goes to your intake)(just make it longer?) to a coke can inside ur engine bay as a temp as it will prob get some oil in it and a catch can should go straight on maybe with over the counter fittings and keep ur intake as is...but like i said im new to theses motors but not horsepower :sorcerer:
so wait mate for someone whos done it to post!
was in the same situation, made my own intake pipe but forgot about the oil hole.
bought a oil breather(which is illegal) until i could drill a hole into the intake pipe.
wat ever u do dont leave it unplugged, u dont want oil drippn onto places that are hot....trust me lol
R34NRG - do you think i should plug it up then? or have something to drip it into, cause i really need my car to get to work tmoz (only about 5km) and i really dont want to take everything apart again
just get a oil breather man.....plug it up with that....and find someone who can modify ur intake, then go to autobarn and buy a long rubber hose....lead it in...bloody easy man.
it woudl seriously cost u like 25 bux.
a nice steak at la pochetta but theres always next week.
fark does anyone else love their steak? mushroom sauce baby...droolz
Edited by R34NRG
mmm. The way mine is set up is to have the hose run to the start of my pod filter, where there is a hole drilled in the rubber (where the pod connects to your intake pipe) and a nipple sealed in. Its alot easier than to modify your intake pipe.
although mine is running a oil catch set up, same deal applies as to where you can tap that breather too :D
Hey guys,
You stock intake will have two hoses going into it, one is for the return of the stock bov and since you aren't running it you wont need that. The other is for the crankcase ventilation and thats the hoses that are running over your rocker cover. You cant block this ventilation off, you need it otherwise you'll drive down the street and your dipstick will pop out and make a nice mess.
You have a couple of options:
1. Modify your new inlet to be able to take the ventilation hose (and this has to be done BEFORE the afm)
2. Get a catch can and run the ventilation hose to that instead, but thats just another shiney can that will stand out in your engine bay and if you get pulled over will get you defected by a retard cop that doesnt know the difference between a bov and pod...
I would just do option 1, but what ever you do dont block that hose off and dont just put one of those "monza" filters on it, the ventilation hose can carry a bit of oil especially when your on full boost and the last thing you want is oil being sprayed in your engine bay, right near a nice hot exhaust manifold.
Edited by R34GTFOUR
i'm still running stock intake pipe, airbox, blow off valve and crank case ventilation system.
the air flow meter bolts right up to the airbox. both the bov and the crank case are plumbed in well AFTER the air flow meter
this image sorta shows how far down the plumbed in lines are. the airflow meter is off the photo!
it makes logical sense that you want the bov air going back through the afm. but definitely not oil.
I'd go for a catch can if i was you, pull out stubs where the current pipes connect to, then get two new screw in fittings, can't remember the size, maybe just over 1/2" BSP? you'll have to check, block the PCV valve off with a blanking screw and remove it from the manifold
Then mount the catch can somewhere in the engine bay and run two lines to it :P
That way you'll be setup for any track work and driving on the street(incase you somehow lose your oil through the breathers...
I think for track(well at least in NZ) your catch can must be equal or greater than your engine, for street I used to just use a 1L one, never had any problems
The coke bottle trick also works, but it's terrible ghetto and I'm sure a cop would defect you for it
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
