Hi All,
Im new to this forum and due to pick up my ER34 this weekend (very excited!!!) and was wanting to know if anybody has debadged there skyline?
Im looking to debadge the badge on the bonnet & nissan, skyline and R34GTT badge on the boot.
Looking for some tips, instructions or pics if anybody has done it before.
Any info would be much appreciated.
Did a search on this forum but couldnt find anything.
Sorry if its a repost.
Thanks.
Rob
https://www.sau.com.au/forums/topic/181145-debadging-r34/
Not sure if I've seen anyone take the badge on the bonnet off, but to take the others off, you would normally use a heat gun or a hair drier to melt the glue and then use some fishing wire to 'cut' the badge out (if you know what I mean).
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3291792
Thank you all for the advise i shall definitely try it, and i wont be holding onto the badges when im done so ill post again when i want to get rid of them.
From what i can remember the skyline badge on the boot was a gold colour......im picking the car up this saturday so ill confirm once ive picked it up.
thanks again
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3292830
Fark, that car in your signature is hot!!! Get your car looking like that and post up some pics. :)
Didnt know they made a GTR kit for a 4door or does a 2 door kit fit on a 4 door anyway?? Hmmm...
Post sum pics when its debadged, im thinkin of doin the same but bot sure how it'll look so u can be the guinea pig :(
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3295403
GOLD!?!?! Interesting....I want to make my 4dr look like that as well,but still dont know what side skirt is that...it looks like east bear on the other pic,but this pic looks a bit different...BTW,have u got the LED tail light~~~
https://www.sau.com.au/forums/topic/181145-debadging-r34/#findComment-3297249
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
