  • Replies 75
Originally posted by inark
lol yeah its always the ISP :D
when was the last time u reinstalled the modem driver? DFM560s arent the greatest modems. Are you using the latest driver? Have you tried locking the modem down to a more stable speed?
Tried a decent external modem?
Could also be the phoneline... things change over time, like line quality... ever seen a telstra techie van around the neighbourhood?
theres so many things that can affect the way it works
Have the latest driver.
Maximum Port speed: 115200
Phone line is new we just bought the house :D and the Phone point is like 2 m from my modem. So everything is fine. its ISP....99%.
Havent seen any vans. my modem is external.
Is iPrimus dial-up any good?
our dialup is as good as any others... wouldnt rate it any higher... if u were to come to primus with that modem i would not sign u up... however im not in sales unfortunately.
whcih chipset is it? RCV?
can u get me the ATIs of the modem?
98/ME
Control Panel>>Modem>>Diagnostics
Highlight the comport>>more info
ATI1
ATI3
ATI5
2k and XP
Control Panel>>Phone and modem>>modem
Highlight the modem>>Properties
Diagnostics>>Query modem
98/ME
ATI1
ATI3
ATI5
2k and XP
06-15-2003 21:20:58.559 - Session Statistics:
06-15-2003 21:20:58.559 - Reads : 30 bytes
06-15-2003 21:20:58.559 - Writes: 76 bytes
ATQ0V1E0 - OK
AT+GMM - COMMAND NOT SUPPORTED
AT+FCLASS=? - 0,1,2,1.0
AT#CLS=? - 0,1,2,8
AT+GCI? - COMMAND NOT SUPPORTED
AT+GCI=? - COMMAND NOT SUPPORTED
ATI1 - 168
ATI2 - OK
ATI3 - V2.210-V90_2M_DLS
ATI4 - V.90 & K56Flex Voice Modem
ATI5 - 040
ATI6 - RCV56DPF-PLL L8571A Rev 33.00/33.00
ATI7 - OK
and it takes like 30s or so to connect.
uve obviously got XP :D
what speeds are u connecting at??
on the advanced tab it will say something like extra initialization commands...
put in there
+ms=12,,,40000
if u connect at less than that then try
+ms=11
yes munkeh... yes they do :D
its a rockie so u shouldnt have too many issues... unless ur line is crap... which u can only get ur local call provider to check with a MOLDS test... altho ur ISP should be able to see what ur line is like and what the connections are like
put in there
+ms=12,,,40000
+ms=11
I connect at 49.2 Kbps.
Typed in "+ms=12,,,40000 " connected at 40.0 Kbps
thats right but it should make it more stable... one of the issues is that ur modem may be retraining..... retraining is where due to either line noise or poor driver support the modem changes modulation.... ie. u connect at 49.2k but during the connection it chops and changes (u wont see this tho)... the only way u will know its doing it is the fact that u may get loss in data flow or disconnected.
Ok, it didnt change anything... still slow... :D its ISP...
but that will slow u down to v34
i cant really do much in way of suggesting lock downs as i cant see ur connections... so it would be useless to use the v34 lockdown unless ur modem was retraining down that low anyway...
lol its physically slower but it might be more stable... i might be able to get u onto a family and friends plan if that still exists around here... i think its like 19.95/month unlimited hours and downloads... and then i can check ur connections and stuff.
Ok, i'll join. is that 12 month contract paying by quarters? coz i wouldnt want to get locked in if its sh!t connection.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
