Parts Available:
- Sr20 piping, clamps, silicone hosing everything needed to fit up a 600x300x76 intercooler FMIC PRICE....???
-Trust e-manage intercept computer and harness brand new in box, never used-$600
Reply or call 0400218118
just the parts in picture now
Edited by super_32
Pics uploaded !!!
COGS- Theres no need for an adaptor. just weld it straight up to ur cooling pipe easy done.. pics are up too now
thanks guys
Edited by super_32
