hey guys. i'm trying to source out a hks ssq bov for a b`day present.
i would of post it in the wanted section but since i need it to be brand new, do you where i can get one in Melbourne?
(try to do a search on it as well)
very grateful if you could point me to the right direction.
cheer have a good weekend
If you are in the south eastern suburbs there are 2 performance shops on Westal road (Crn Westal and Centre). One is evolution R and i forget the other. Both in the same complex.
You are willing to pay over $700 for something that goes psshh?
wow... haven't seen that name for a while, where have u been the last 2 years Kris? FYI - Evolution R is now known as RE Customs, and N1 distribution no longer exist. RE Customs have relocated to a different factory as well.
Fei - RE customs can order a new HKS SSQV BOV, may have in stock... ring the workshop on 9548 3414 or drop in on weekdays 16 Yiannis Court Springvale. It will definitely be less than $700 :)
:P
thank alot GTTR. I give them a call.
well it not for me, my friend buying it for her bf. i rather use that money on something that would make my car perform better =)
:P
Disregard! lmao, damn i'm not with it now hey :)
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
