I can personaly vouch for these wheels and for Leech_
Genuine Volks - Very nice!
Leech_ Genuine, trustworthy guy...
Im sad to see these nice wheels go Leech_ I would buy them if I had the dough.:D
https://www.sau.com.au/forums/topic/181469-sold-sold-sold/#findComment-3297625
cheers Mick yea they really suit the skyline. Also they come with the nuts for the rims as the GT-C's need a special nut. it has a special key for all of them as well so they would be a lot harder to steal.
https://www.sau.com.au/forums/topic/181469-sold-sold-sold/#findComment-3299214
Garage Menace - I have never had them at $2200 they were at $2850 originally but thanks for the free bump anyways :3some:
If the buyer only wants the rims i can take a bit off the price though
Mate,
My sincerest apologies, however if you check out this link:
http://www.skylinesaustralia.com/forums/in...=179981&hl=
You can see where I was confused...
Another free bump for the stuffup and good luck with the sale.
https://www.sau.com.au/forums/topic/181469-sold-sold-sold/#findComment-3311109
as listed up the top asking $2050 at this stage. If they don't sell at around this price i will list them on ebay and see what i can get for them. Worst case i put them away for 3 months and try again.
https://www.sau.com.au/forums/topic/181469-sold-sold-sold/#findComment-3332835
  • 3 weeks later...
cleaned up the stickers so they are gone now and gave the lips a bit of a polish and they have come up really well. I will leave them at $1750 so if anyone is interested let me know.
thanks,
Leigh
https://www.sau.com.au/forums/topic/181469-sold-sold-sold/#findComment-3377219
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
