Since getting my new button clutch I have found that a blip of the throttle on down shifting is MUCH nicer on the clutch. If I don't give the throttle a blip and I'm trying not to compression lockup (i.e. slip it a little) I can feel the clutch skip and it generally doesn't feel nice at all. I kinda of feel like a fool driving around giving it a rev in between each downshift but it is certainly much kinder to the clutch :)
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3322021
heel toe is good if used in the right manner, little old grannys in honda jazzes wouldnt exactly be going fast enough to warrant heel toeing.
you never know.....
what about the granny that i saw (white hair and all) in a maserati convertible.......... the wind in her white hair and all......she probably does a lot of heel-toe around town when shes trying to open a can of whoop-ass on the other drivers :domokun:
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3347351
geof, im concidering getting a ppg dog box. (i know how they work) can you give me some info on the shifting technique needed for them? ive kinda an idea but no experiance.
par engineering have a good section on it. but im just after some first hand experiance. cheeers
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3350566
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
