Since getting my new button clutch I have found that a blip of the throttle on down shifting is MUCH nicer on the clutch. If I don't give the throttle a blip and I'm trying not to compression lockup (i.e. slip it a little) I can feel the clutch skip and it generally doesn't feel nice at all. I kinda of feel like a fool driving around giving it a rev in between each downshift but it is certainly much kinder to the clutch :)
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3322021
heel toe is good if used in the right manner, little old grannys in honda jazzes wouldnt exactly be going fast enough to warrant heel toeing.
you never know.....
what about the granny that i saw (white hair and all) in a maserati convertible.......... the wind in her white hair and all......she probably does a lot of heel-toe around town when shes trying to open a can of whoop-ass on the other drivers :domokun:
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3347351
geof, im concidering getting a ppg dog box. (i know how they work) can you give me some info on the shifting technique needed for them? ive kinda an idea but no experiance.
par engineering have a good section on it. but im just after some first hand experiance. cheeers
https://www.sau.com.au/forums/topic/181543-heel-toe/page/2/#findComment-3350566
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
