First off:
There is no 'drop in cam/s' for the Rb26. If you mean doing it right. You need a new set of cam retaining studs and clearences will no doubt need a few extra shims. Along with the usual gaskets.
As for lift without machining;
10mm lift requires removal of a little head material. I'd say a new set of heavier duty valve springs wouldn't be a bad move either.
9mm lift is about it. eg Tomei poncams.
hope that helps
https://www.sau.com.au/forums/topic/181570-cams/#findComment-3298192
