need major help guys i cannot removing the rear seats in my r32 gts and its really pissing me off. there is no strap or lever i can see or find around the seat i can pull the seat a lil and hear it latched on somthing but i dont wanna ruin it. how do i remove them??.
thanks
https://www.sau.com.au/forums/topic/181807-removing-rear-r32-gts-seats/
put your front seats forward as far as possible.
hop in the car and push the rear bench backwards towards rear of car and lift at the same time. then i think the rear part is bolted in i cant remember exactly but this should help you out...good luck
I think there's two bolts either down the side or back of the lower part of the seat, if I remember right. Once they're out, it's as Jeffers says. Push the seat back and pull it up. There are two small elongated U-shaped metal tabs that go down into the floor pan through two holes which have plastic clips in them to hold it in place. You need to give it a bit of 'gentle persuasion' to pull them up and out. When I took mine out, I got the seat lifted a bit, then stuck a screwdriver inside the U-shaped tab and levered up at the same time.
Edited by Mark_McQ
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
