Hi All,
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
RB20DET/RB25DET Factory Blow Off Valve, Modified to handle more boost
Runs 16PSI all day long no leaks.
Slightly Flutters between gear changes
Drilled the Hole slightly bigger and blocked with with silicon and a stainless steel screw
Modified as per the tutorial on SAU
Will install into your car as well if your nice :P
Reason For Sale: Need To Upgrade When Turbo Comes
Flexible Antenna, Replaces Your Broken Electric Antenna
Reason For Sale: Shaved off my antenna hole for aesthetic reasons
Price: $10
Edited by johnnilicte
https://www.sau.com.au/forums/topic/181922-everything-sold/
Anyone interested?
btw, I have some other car accessories for sale on eBay if anyone is interested... and if you offer a reasonable price I'll end the auction and sell it to you.
Just search for the sell "johnnilicte" on eBay, which is myself anyhow.
https://www.sau.com.au/forums/topic/181922-everything-sold/#findComment-3304878
This is interesting, what did you do to modify it to hold higher boost?
Just curious, as there is a big thread about BOV's at the moment..
I just plugged up that 3mm hole as per one of the tutorials on SAU...
I believe that hole assists the piston in lifting up when the throttle is closed, pressured air flows through it to lift up the piston. (someone correct me if I am wrong)
https://www.sau.com.au/forums/topic/181922-everything-sold/#findComment-3305154
RB20DET RB25DET same BOV, same base mount.. just the RB20DET sits vertical and uses a longer rounded piece of rubber hose for the plumb back, whereas the RB25DET sits horizontally and uses a straight piece of hose.
I've got the rounded hose if anyone wants it for their RB20DET....
and like I said, if your a local, I'll even fit it for you, provided your nice =)
https://www.sau.com.au/forums/topic/181922-everything-sold/#findComment-3307181
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
