Heres the measurement as promised.
Not sure of the height of the stock bumper but from what I can remember there was only about an inch difference between the two.
Looks like theres still plenty of ground clearance. Has the car been lowered - coilovers/springs & by how much?
  • Replies 90
Posted Images
Sorry for the late reply. Yes the car has been slightly lowered with Bilstein shocks but still using stock springs. Bilstein shocks from SK's groupbuy have built-in adjustable circlips, each with 8mm in between. Mine is at the lowest setting which in theory should be 24mm lower both front and rear.
Front 380 mm - 24 mm = 356 mm
Rear 370 mm - 24 mm = 346 mm
Forged, your Skyline looks awsome, congrats.
I too ordered the Carbon Fibre East Bear Bonnet from Powerplay as well $2K ,paid for it but still waiting for it since June!!!!!!!!
no returned calls or no reply to my emails, getting concerned.
I need it as i got the Top Secret bar waiting to fit as well.
U've been waiting since June and u've paid for it? Damn thats pretty bad customer service.
Ive been trying to get in contact with Powerplay as well for the last 3 weeks just for a quote, no pickup's, no calls returned. Are they still in business?
Since June?!?! It's taking them ages. I would've cracked the shits after 2 months.
Thanks DOSKI.
Did you leave a deposit or full payment? They can be a bit slow with communications sometimes but keep trying and make sure you leave a message everytime they will get back to you eventually. I paid a deposit and waited for 3 month till they called again no problems at all.
  • 3 weeks later...
Thanks DOSKI.
Yeah , i paid in full via visa card. originally told 4 weeks then after 4 weeks i called and was informed it was only just leaving Japan that week i called so i waited another 4 weeks and no reply to calls or emails , still nothing but im told they will come through with the goods, im just getting mad eager as i got my top secret front bar to fit and need the bonnet to make the correct fitment.I'll keep you posted. Im pretty sure they wouldnt rip me of, they got a good reputation and Jo-anne was very helpfull and courtious when i did speak.
  • 5 months later...
Ive been waiting 6 months for a eastbear kit, and to match that I bought it off another forum member who was already waiting for it for 6 months!! so 12 month wait SICK! powerplay are useless
Unfortunate to hear mate, don't know whats the deal but I did not have to wait for that long. Hope you work it out with them soon.
